1页(1条)
SMath Studio 0.95 (17 June 2012) - 消息
New SMath Studio 0.95 available
Last changes
- New improved MSI installer created for Windows (new design and features);
- End User License Agreements added to the Setup package;
- Functions improved: augment(..), stack(..);
- Default list of expanded tabs of the Math Side Panel corrected;
- Restored ability to open files with Protected Area regions;
- Appearing of Protect Region menu item prevented for bottom part of the Area Region and for Separator Region;
- Fixed critical errors appears sometimes on XMCD files reading (unsupported styles issue);
- Fixed support for importing subscripts from XMCD files for different localizations;
- Symbolic engine evaluation error fixed appeared as changing order of multipliers contains undefined variables;
- Symbolic engine evaluation error fixed appeared for several operations between Matrices and scalars;
- Fixed critical error appears sometime on Unde/Redo using;
- Refactoring.
System requirements
- Desktop (Windows):
Framework: .NET Framework 2.0 - Desktop (Linux):
Interface languages (34 languages)
Free Download
- Desktop Windows (desktop computer with Windows OS):
SMathStudioDesktop.0_95.Setup.msi (Date: 17.06.2012. File size: 1.62MB)
SMathStudioDesktop.0_95.Portable.exe (Date: 17.06.2012. File size: 17.98MB) - .Net Framework 2.0 doesn't required - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_95.Mono.tar.gz (Date: 17.06.2012. File size: 846.13KB) - last version of Mono distributive required!
Note: No current version of SMath Studio Handheld release will be introduced. Please use the latest stable handheld version (0.90).
Tutorial
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
3位用户喜欢此帖子
1页(1条)
