issue with user defined diff
issue with user defined diff - [not a bug] - 消息
#1 已发布: 2018/1/29 16:41:29
983个赞,共6,866个帖子。
Copy this section, paste in 6484 ... turns read.
Don't understand error message ?
Bug 6484.sm (10.84 KiB)已下载 1298 次。
#2 已发布: 2018/1/29 21:05:52
983个赞,共6,866个帖子。
... not a bug wrt the construction.
Simply, it creates "shadow in the context" past some of the Alvaro coolprop.
It works at top of the work sheet. Whatever: can't understand the error message.
#3 已发布: 2018/1/30 02:34:50
325个赞和1个踩,共2,052个帖子。
Sorry Jean, I do not quite understand your point. The picture of regions with the error are out of the context. What was the value of object "f" and "g" prior the error messages? The same name "f" can have a variable "f" or a function "f(x)" and they can exist both. Maybe there might be a problem.
#4 已发布: 2018/1/30 10:51:07
983个赞,共6,866个帖子。
Within the CoolProp context, f & g may have relationship with their respective
f(T,v) Helmholtz free energy equation,
g(T,p) Gibbs free energy equation
It works at top of the work sheet, but not within the context: shadow in the context.
Thanks Radovan.
Maths CoolProp Alvaro.sm (61.76 KiB)已下载 1334 次。
2位用户喜欢此帖子
Davide Carpi 2018/1/30 11:05:00, Radovan Omorjan 2018/1/31 02:48:00
#5 已发布: 2018/1/30 11:04:41
1,443个赞,共2,936个帖子。
Ah, now I see it...
seems related to the fact that the diff function is overridden in amid of the worksheet (see Ndiff, Nint collapsed area)... the unapply() function makes anything (even numbers) as functions, must be improved a little
