Division between elements of matrices
Division between elements of matrices - 消息
#1 已发布: 2013/5/26 07:08:29
experimentator
experimentator
1个赞,共21个帖子。
First of all, I think Andrey the work you do is astonishing and thanks to all the community, too.
I have a problem, waht is wrong?
Learning by doing
#2 已发布: 2013/5/26 08:25:00
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
1. You should not use i's and j's as indices, because they also designate imaginary part of complex numbers. In some versions some of them, or both, cause errors when used otherwise.
2. You could use I and j as indices of k, not of C[k] or A[k].
It would be better if you attach the file.
Edit: Oh, it looks like you cannot assign anything to nested matrices...
Seems like you only can assign the whole new matrix to C[k].
С уважением, Михаил Каганский
#3 已发布: 2013/5/26 08:30:38
325个赞和1个踩,共2,052个帖子。
Try this
[MATH=eng]for(k,range(1,rows(A)),line(for(i,range(1,rows(),for(j,range(1,cols(),el(c,i,j):el(B,i,j)/el(el(A,k),i,j))),el(C,k):c,2,1))[/MATH]
[MATH=eng]C=mat(mat(4,2.5,2,1.75,1.6,1.5,3,2),mat(0.571,0.625,0.667,7,4,3,3,2),2,1)[/MATH]
It seems that direct assignment of a matrix element in a nested matrix is not allowed. Try to avoid such constructions - it will give trouble.
#4 已发布: 2013/5/26 08:30:52
1,362个赞,共2,276个帖子。
The problem is in using nested indices on the left hand side. That does not work just as linear indexing of pre-allocated matrices does not work (would save a loop in the example).
#5 已发布: 2013/5/26 13:58:08
experimentator
experimentator
1个赞,共21个帖子。
I thank you all!
Learning by doing
