[SS-2302] Smath File Crash
[SS-2302] Smath File Crash - 消息
#1 已发布: 2016/3/4 23:48:32
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
The following Smath File worked fine under 97.5890. It opens a Excel data file for analysis.
But it crashes under 98.5905.
Why this happens?
未找到文件。未找到文件。
#2 已发布: 2016/3/5 08:08:32
1,443个赞,共2,936个帖子。
The crash is triggered in sum(1)
Even copying the Q matrix in a definition on the canvas the crash still happens.
Issue isolated: crash sum 1.sm (318.57 KiB)已下载 1347 次。
P.S. try sum(identity(30)) and sum(identity(50)), the second one crashes for me
opened as issue SS-2302
#3 已发布: 2016/3/5 08:59:45
983个赞,共6,866个帖子。
Try this instead
#4 已发布: 2016/3/5 09:07:29
983个赞,共6,866个帖子。
... sorry, forgot to attach the file
crash sum 1.sm (322.21 KiB)已下载 1349 次。
#5 已发布: 2016/3/5 12:44:48
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
The second one crashes for me too
Davide Carpi 2016/3/5 13:38:00
#6 已发布: 2016/3/5 18:33:25
2,344个赞,共4,057个帖子。
组: Super Administrator
2位用户喜欢此帖子
Davide Carpi 2016/3/5 21:05:00, NDTM Amarasekera 2016/3/6 09:53:00
#7 已发布: 2016/3/5 20:55:35
983个赞,共6,866个帖子。
Ioan,
You can dedicate a function "VectorMatrixSum(data)"
Unwrap has many more applications, thus interesting.
Under the hood, your combined Sigmas, they first
Unwrap. Matrices don't exist in computing Machinery.
Matrices exist as serialised components.
The "BombCompute Mathcad 11", copy/paste a fair size
matrix [16000000 per say] takes substantial time.
"Warning: the requested operation may take long time".
Can't be more true.
Cppy/paste 16000000 vector: NO warning message... done.
Chers, Jean
#8 已发布: 2016/3/6 09:49:45
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Thank you Andrey.
The problem on Smath file crash is now solved.
Andrey Ivashov 2016/3/6 17:37:00
#9 已发布: 2016/3/7 00:44:24
983个赞,共6,866个帖子。
Thank you Andrey.
"now solved", maybe not so wrt matrix manipulation.
Observe the matrix scale code: M-Min(M)
I found out this built-in code is weak, prone to failure
with incorrect error message " Matrix is not invertible".
There is no matrix inversion involved. Observe the robust
code doing same. Example has low numerical values. At values
in the order of 10^10, module [1] fails.
Utilities Matrix Scale.sm (14.19 KiB)已下载 1335 次。
Davide Carpi 2016/3/7 09:19:00
