Questions of graph of a function
Questions of graph of a function - 消息
#1 已发布: 2024/7/31 00:55:33
Prmtv
Prmtv
0个赞,共49个帖子。
Hello! Please tell me for 2 questions:
1) How to build a graphs of function if the document has units of measurement? If I do "Ignore inits", then everything works. But I would like to with units of measurements
111.sm (33.1 KiB)已下载 1731 次。
2) Using plugin ComboBox I want to build graphs of 4 functions
Graphs of functions σ.x(x), σ.t(x), Mx(x) are built.
未找到文件。 未找到文件。 未找到文件。
Graph of functions σ.ekv(x) is not build. Why?
#2 已发布: 2024/7/31 01:26:33
600个赞,共1,381个帖子。
Don't "Ignore units", eliminate them.
Easiest way is to divide.
#3 已发布: 2024/8/1 00:23:24
Prmtv
Prmtv
0个赞,共49个帖子。
In my example it doesn't work like that.
#4 已发布: 2024/8/1 01:37:29
1,558个赞,共1,868个帖子。
Очень странное поведение, возьму на заметку. Компоненту не нравится выражение под знаком корня.
#5 已发布: 2024/8/1 02:55:39
1,362个赞,共2,276个帖子。
The success of plotting seems to depend on how the expression is accessed. Possibly it is a Combobox issue.
BTW, in Maxima, the intermediate definition of P is not required. This is a necessary step for X-Y Plot only.
111_Kr.sm (60.2 KiB)已下载 1674 次。
#6 已发布: 2024/8/1 09:27:50
Prmtv
Prmtv
0个赞,共49个帖子。
Если строить график отдельно, то он строится, проблем нет. Именно при Combobox'е не хочет
#7 已发布: 2024/8/3 01:58:09
Prmtv
Prmtv
0个赞,共49个帖子。
Thanks for the answer!
How can I replace it?
on this
#8 已发布: 2024/8/3 03:49:27
600个赞,共1,381个帖子。
I only meant to say don't ignore units unless it is utmost necessary.
Here is your file totally working with units and plotted.
111_examination.sm (38.72 KiB)已下载 1746 次。
When I talk about your problem, I guess it is a parse bug of combobox.
Because it can plot normally when function called directly.
And radiobutton and combobox list is not affected if you use like this.
未找到文件。 未找到文件。
This combobox issue is not limited to XYPlot, 2DPlot is affected too.
When combobox result is directly your symbolic function, it doesn't work.
However, when your function is simplified someway, it can be plotted.
This bug should be examined by author of combobox plugin.
#9 已发布: 2024/8/3 05:39:17
1,362个赞,共2,276个帖子。
on this
I guess you want to set the limits depending on the selected function.
Let the combobox return the index of the selection and then use it to pick the appropriate values from lists.
In Maxima, you also can set the axes labels and the trace legend text using SMath expressions.
#10 已发布: 2024/8/3 18:45:06
600个赞,共1,381个帖子。
Most of time, eval() or line() is your friend.
This change made your function available to plot.
#11 已发布: 2024/8/4 01:21:28
Prmtv
Prmtv
0个赞,共49个帖子。
Thanks everyone for your answers!
#12 已发布: 2024/8/4 01:36:26
Prmtv
Prmtv
0个赞,共49个帖子。
on this
Can you tell us more?
If possible with an example.
Yes, I would like to substitute values ​​from the results for set the limits
#13 已发布: 2024/8/5 03:51:31
1,362个赞,共2,276个帖子。
111_Kr2.sm (60.85 KiB)已下载 1707 次。
#14 已发布: 2024/8/5 04:32:19
600个赞,共1,381个帖子。
I like the way limits determined by YLimMin, XLimMax, etc.
However, if you rename XYPlot to XYPlots or Plot1 or whatever, this method doesn't work particular plot.
Actually, all XYPlot are affected by XYPlot.option disregarding name of plot.
Is this a bug or a feature?
sergio 2024/8/5 15:36:00
#15 已发布: 2024/8/5 04:45:30
1,362个赞,共2,276个帖子。
As far as I understand, you can control multiple plots individually by providing vector values to the XYPlot-variables. In the settings you select select SourceType->PropertyGrid and provide the index to use for accessing the values.
You find an example in the interactive handbook (Plugins->X-Y Plot Region).
#16 已发布: 2024/8/8 23:42:02
Prmtv
Prmtv
0个赞,共49个帖子。
Thank you very much! That's what I needed.
The only question is: does SMath have auto-scaling of axes as it was in Mathcad? this would greatly simplify the process)
#17 已发布: 2024/8/9 01:43:28
1,558个赞,共1,868个帖子。
Использование Properties source - это исторически первый способ управления компонентом из документа, он был оставлен для совместимости со старыми документами.
Автомасштабирование в компоненте XY Plot не реализовано из-за того, что я не нашел удобного алгоритма поведения для комбинации явных и неявных графиков. Для отображения неявного графика область должна быть задана конкретно, а для автомасштабирования наоборот не задана.
#18 已发布: 2024/8/9 15:04:34
1,558个赞,共1,868个帖子。
I can add this option to customize the properties
#19 已发布: 2024/11/12 07:02:29
Mo
Mo
0个赞,共34个帖子。
hi, For some reason the "Property source" is not shown now. I am using version 1.2 build 9018 dated 09-sep-2024.
how to assign/control plot properties now?
#20 已发布: 2024/11/12 08:08:01
1,558个赞,共1,868个帖子。
The answer can be found here.
