Some plugins installation fail
Some plugins installation fail - Maxima, Excel Files, Script Region and muMath Files plugins installation don't work - 消息
#1 已发布: 2021/6/10 03:47:53
Ibrahima Fall
Ibrahima Fall
0个赞,共11个帖子。
Hi all!
I have problem when I try to install the following plugs:
Excel Files plugins
MaximaPlugin
Script Region
muMath Files plugin
I get this message: "Plug-in(s) installation failed"
All plugins are working fine except these four that I mentioned.
I am under Windows 10 pro. I use maxima-5.45.0 and Office 365.
Any help would be welcome.
#2 已发布: 2021/6/10 16:12:32
1,362个赞,共2,276个帖子。
Confirmed for Maximaplugin with a new portable version 7822.
However, automatic upgrade of an installed version with Maximaplugin to 7822 works. Maximaplugin remains functional.
Didn't test with Maxima 5.45 though, but the problem is before you even can specify the path to Maxima.
#3 已发布: 2021/6/10 19:35:46
2,344个赞,共4,057个帖子。
组: Super Administrator
Maxima plug-in corrected.
Please update it using Extensions Manager.
#4 已发布: 2021/6/10 20:48:20
Ibrahima Fall
Ibrahima Fall
0个赞,共11个帖子。
Thank you Andrei for the updates.
Now Maxima, Excel Files and muMath Files plugins work fine.
Only Script Region plugin don't work.
#5 已发布: 2021/6/12 04:35:52
2,344个赞,共4,057个帖子。
Script region rebuilt and can be installed to the latest SMath Studio version again.
Thanks.
#6 已发布: 2021/6/12 06:51:02
Ibrahima Fall
Ibrahima Fall
0个赞,共11个帖子。
Thumb up Andrei.
