SMath论坛 SMath Studio Samples Thermal Physics [Rod in Cylinder] 1页(3条) Thermal Physics [Rod in Cylinder] - Thermal Physics [Rod in Cylinder] - 消息 转到最后一个帖子 #1 已发布: 2018/2/2 13:30:01 Jean Giraud 983个赞,共6,866个帖子。 组: User This project is reconstructed from various contributions.Done 6179 ... compatible 53461. Discrete solution [convenient export]2. Model function [Genfit]3. Analytical solution [Maple]JeanMaths Thermal Physics - Rod in Cylinder_Genfit.sm (61.98 KiB)已下载 1379 次。 #2 已发布: 2018/2/2 17:52:55 CBG 78个赞,共312个帖子。 组: User I get the following error: "The input string does not have the correct format" in Smath Studio 98.6606Best RegardsCarlos #3 已发布: 2018/2/2 17:59:50 Andrey Ivashov 2,344个赞,共4,057个帖子。 组: Super Administrator WroteI get the following error: "The input string does not have the correct format" in Smath Studio 98.6606The same error with earlier versions. I've reproduced it on 0.98.6484.Seems like locale related issue in the graph plug-in. 1页(3条) 有新帖 无新帖
