Export to Tab Delimited Text file
Export to Tab Delimited Text file - Messages
#1 Posted: 2016/8/31 22:28:37
Ernesto
Ernesto
13 likes in 74 posts.
Is there a direct way to export a matrix to a tab delimited text file??
I have been exporting it to excel, then saving as a tab delimited text file. I'm hoping I could skip this extra step.
#2 Posted: 2016/9/1 02:26:59
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
http://en.smath.info/forum/yaf_postst1642_Data-Exchange-plugin.aspx
С уважением, Михаил Каганский
#3 Posted: 2016/9/1 13:32:32
Ernesto
Ernesto
Thanks Mike for pointing me to the other thread. I looked over the 8 pages of the thread, but no where does it say anything about tab delimited values, only comma delimited values.
#4 Posted: 2016/9/1 13:54:56
1,441 likes in 2,932 posts.
I might try to add an optional argument to setup a custom separator
As alternative you can build your own functions using fwrite() from DataExchange + var2str(...) from CustomFunctions
example attached: export2tsv.sm (6.07 KiB) downloaded 1022 time(s).
Ernesto 2016/9/1 19:33:00
#5 Posted: 2016/9/1 18:39:17
Mike Kaganski
Mike Kaganski
Sorry for not being clear.
There's no such standard as "tab delimited values file", only CSV, but the CSV allows for different kind of separators.
As Davide says, it requires a developer to add that ability, and I suppose, that would be great.
#6 Posted: 2016/9/1 19:33:10
Ernesto
Ernesto
Thanks for the file Davide, worked perfectly!
