Operation cannot be performed with units and solution exceeding max allowed numerical values
Operation cannot be performed with units and solution exceeding max allowed numerical values - 消息
#1 已发布: 2015/11/17 14:47:22
aero
aero
0个赞,共12个帖子。
I am getting the error of "Operation cannot be performed with units but I redefined the values with new variable names which has no unit but I am still getting the same error. I need suggestions to resolve this issue. I have attached the Smath file and a screen shot of the same.
Thanks !
#2 已发布: 2015/11/17 17:01:25
Ernesto
Ernesto
13个赞,共74个帖子。
Post the file.
#3 已发布: 2015/11/17 17:07:51
dio pants
dio pants
16个赞,共180个帖子。
What is this a calc of? Do you have a good known example to check against?
Check your operations- calcs dependent on variables need to be below or to the right.
Your units are goofy. break out a pencil and paper and do the dimensional analysis to see how your calc is working, or really not working. SMath is REALLY good at keeping track of units. it is doing exactly what you are telling it to do.
#4 已发布: 2015/11/17 20:23:20
1,443个赞,共2,936个帖子。
Seems that tanh(x) returns a "number above the max" error if x > 354, a "division by 0" error if x < -228 (reported as BUG SS-2284)
About the units, the tanh argument must be dimensionless; m*Lc can't be dimensionless because m is not the inverse of a length (your definition of m contains the Boltzmann constant and 2 lengths)
#5 已发布: 2015/11/18 04:40:35
2,344个赞,共4,057个帖子。
组: Super Administrator
Hello.
I've fixed this issue and here is corrected SMath.Math.Numeric.dll SMath.Math.Numeric.dll.7z (25.23 KiB)已下载 774 次。
Please put it into installation directory of SMath Studio.
Fix will be included into new version of the program.
Regards.
4位用户喜欢此帖子
Davide Carpi 2015/11/18 05:18:00, sergio 2015/11/18 05:48:00, Radovan Omorjan 2015/11/18 06:22:00, ioan92 2015/11/18 09:16:00
