"Operation cannot be performed with units" for exponential function
"Operation cannot be performed with units" for exponential function - 消息
#1 已发布: 2023/6/25 14:26:10
EngMath
EngMath
0个赞,共51个帖子。
I get the "Operation cannot be performed with units" error for a complicated equation involving exponential functions which seem to be the culprit:
Here's the file:
Operation units.sm (17.06 KiB)已下载 1508 次。
Is there a mistake in this equation in SMath ? Here's what it looks like in the original:
#2 已发布: 2023/6/25 15:31:07
127个赞,共342个帖子。
The main error you made is in obtaining the pulsation from the frequency.
Also in the formulation of X5 there were two or three errors of evaluation of the SIN (or cos) of the pulsation multiplied by a time (attention to the use of parenthesis)
Operation_units.sm (17.45 KiB)已下载 1454 次。
#3 已发布: 2023/6/25 16:23:53
EngMath
EngMath
0个赞,共51个帖子。
Thank you very much. The formula for ω_n from the book did look suspicious to me so I tried removing f_n from it but it didn't help so I thought that the main problem lies somewhere else.
#4 已发布: 2023/6/26 06:13:35
1,443个赞,共2,936个帖子。
That's a strange hybrid; the equations should be the following:
#5 已发布: 2023/6/26 11:09:04
EngMath
EngMath
0个赞,共51个帖子。
How can I plot the result as x(t) for t=0 to t=12 s ? From what I remember, plots require x as a variable so I tried with u(x) but I still can't make it work even with all the occurrences of t replaced with x (although I'd rather avoid doing that):
Operation units fixed with plot.sm (16.57 KiB)已下载 1449 次。
#6 已发布: 2023/6/26 11:41:54
1,443个赞,共2,936个帖子。
You have to manage the variable [x] and the result [f(x)] units
2023-06-26 16_39_37-SMath Solver - [Operation units fixed with plot.sm_].png
