Can't calculate minus power
Can't calculate minus power - 消息
#41 已发布: 2016/9/1 20:27:28
983个赞,共6,866个帖子。
You can do like in Mathcad 11 => make an Smath work sheet template.
Example: in the right bottom corner your company cartouche.
cartouche: logo, document, designed by ... date not needed because
auto-dated in the header, auto-paging in the footer.
Try it
#42 已发布: 2016/9/5 04:01:21
Berk Koç
Berk Koç
0个赞,共21个帖子。
Try it
I think I replied this post yesterday but now I see that there is no reply from me interestingly.
I don't know how to make ws template. I was using a Turkish program based on mathcad. But I don't know which version of mathcad was based on. The program is out of date now and not supported. So I don't know how mathcad setup was.
I suppose there must be some tags to add the below fields to have images maybe.
#43 已发布: 2016/9/5 10:40:17
Berk Koç
Berk Koç
0个赞,共21个帖子。
I don't want to use this function ever. As you could see for mathcad I don't need to remember to add vectorize function to solve the equations.
I'm afraid, that this is not exactly what you want, but to make some things clear.
Is there any way to plot silo with given dimensions showing the dimension of the cylindrical part, hopper part etc.?
#44 已发布: 2016/9/5 12:49:47
983个赞,共6,866个帖子。
Smath is not a CAD tool, but lot of math geometrics are easy.
We have even done the W truss ! Put your dimensions in pixels
and get inspired from the attached. Are you still after your
logo in the header ? I did in Mathcad with a tiny logo, but
didn't save. There is a universal code to upload an image in
a document but don't recall [kind of gadget to me].
Inst_Filtrate Bin.sm (31.59 KiB)已下载 1377 次。
#45 已发布: 2016/9/6 02:56:52
Berk Koç
Berk Koç
0个赞,共21个帖子。
I couldn't manage to put a logo on top of the sheet. I think there must be a tag like &[IMAGE] which is similar to &[DATE] or a visual editor. Is it only way to put a background that has logo on top?
#46 已发布: 2016/9/6 09:59:19
983个赞,共6,866个帖子。
Yes, there is way in Mathcad 11. I lost the code because it has limited interest.
The logo image must be not higher in size than the header text, otherwise it could
be 1" ... making the print horribly messy.
If you want your logo at the top left of the work sheet: just paste it here.
If your logo is not too big, then on right, add some lines of text [author, project
short description ...] Don't put date here, when saved, Smath dates in the header.
#47 已发布: 2016/9/6 10:37:06
Berk Koç
Berk Koç
0个赞,共21个帖子。
Ok thank you, I will add background with header to the sheet. That's the only way I could manage. But I have to make some arrangements because all the text is now beyond the image on background.
#48 已发布: 2016/9/6 11:14:59
983个赞,共6,866个帖子。
Something you don't catch: bacckground is over the entire work sheet.
Delete my logo, paste yours ... that's it .
Here is the code to upload an image, Smath does not take in header.
#49 已发布: 2016/9/6 17:31:37
Berk Koç
Berk Koç
0个赞,共21个帖子。
Sorry for the dumb question: how to use this code?
