1页(4条)
Print Preview problem - 消息
In my system (Ubuntu 9.04) I can only print preview once. If I do the second time it just show a blank gray preview. I have to close SMath and I can print preview again, but only one time.
Is that a bug or it hapens only in my system?
Waluyo
Waluyo
I installed in another system, Laptop, Ubuntu 8.04. I have the same problem (print preview only once)
I have tried in two different machines and found the same problem.
regards
Waluyo
regards
Waluyo
Windows version has no such issue. Will check it on Mono soon. Thanks for the report.
Yes .. I just installed in Windows OS, there is no problem at all. I tried running SMath in two different Ubuntu machines, the same problem. Anyone using Ubuntu found the same problem? This is my mono version, in Ubuntu 8.04:
Mono JIT compiler version 2.4.2.3 (Debian 2.4.2.3+dfsg-2~bpo50~dhx1)
1页(4条)
