Vectors creation with ranged indices
Vectors creation with ranged indices - How to use vectors with subscripts (by typing: [) - 消息
#1 已发布: 2018/3/21 10:17:31
Rens
Rens
0个赞,共4个帖子。
Does anyone know how to use vectors with subscripts (by typing: [) in SMAth as I have done in the attached Mathcad file (.pdf + .xmcd). I have tried it in SMath (see the attached SMath file) but this does not work in the same way. Does anyone knows a workaround?
Best regards,
Rens Servais
未找到文件。未找到文件。未找到文件。
#2 已发布: 2018/3/21 10:54:39
1,443个赞,共2,936个帖子。
Hello Rens,
You can do it in the same way, but indices here are base 1 instead of base 0
SMath file (r1).sm (4.53 KiB)已下载 1227 次。
#3 已发布: 2018/3/22 07:12:23
Rens
Rens
0个赞,共4个帖子。
Thanks a lot Davide!
Rens
#4 已发布: 2018/3/22 11:09:04
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2.93 KiB)已下载 1326 次。
#5 已发布: 2018/3/22 11:20:17
1,443个赞,共2,936个帖子。
What would be the expected result?
#6 已发布: 2018/3/22 11:26:42
Arie
Arie
94个赞,共285个帖子。
You had Count as subscript instead of index in the loop.
Range2Vec program.smz (2.93 KiB)已下载 1321 次。
#7 已发布: 2018/3/22 11:26:57
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Wrong subscript ... Fixed Range2Vec.smz (3.31 KiB)已下载 1350 次。
