Multi line text
Multi line text - 消息
#1 已发布: 2010/11/11 18:34:26
László Radnay
László Radnay
0个赞,共9个帖子。
Hi!
Is it possible to use multiline text in smath?
I have just found singel line text.
Thank you for your help!
#2 已发布: 2010/11/11 19:58:54
maweilian
maweilian
5个赞,共103个帖子。
Yes, it is possible.
Create a text region as you normally would (i.e. using 'double quote' key). When you reach the end of a line, use Ctrl+Enter ( or Shift+Enter) to go to the next line. At this point, Smath has no automatic text wrapping.
See this wiki page for more keyboard shortcuts: Keyboard Shortcuts
#3 已发布: 2010/11/12 04:08:24
325个赞和1个踩,共2,052个帖子。
Yes, unfortunately there is no word wrapping. We should be careful when typing text lines in order not to pass over the right edge of the printing area. Print preview can help here.
#4 已发布: 2010/11/19 06:25:38
László Radnay
László Radnay
0个赞,共9个帖子。
Hello!
Thank you for your help! It works, and it helps me a lot!
#5 已发布: 2014/11/5 14:05:36
zapzapouch
zapzapouch
0个赞,共27个帖子。
Is this still true 4 years later? There are no plugins that provide a plain text box with word wrapping and non-monospace font, formatting of a few words and not others, etc?
#6 已发布: 2014/11/5 14:15:01
1,443个赞,共2,936个帖子。
Is currently under development (see here).
About the wrapping is a feature planned but I can't guarantee that this will be available soon.
