Problems with Matrix inversion
Problems with Matrix inversion - 消息
#1 已发布: 2012/4/18 12:07:45
baldu
baldu
0个赞,共4个帖子。
i have some Problems with Matrix Inversion:
the Matrix is:
http://s7.directupload.net/file/d/2864/2qiobdfh_jpg.htm
the Result doesnt fit to Mathcad result:
http://s14.directupload.net/file/d/2864/lsxr79tp_jpg.htm
http://s1.directupload.net/file/d/2864/r3enm3au_jpg.htm
Do you know that Problem? or did i use wrong Syntax?
Thanks!
Adrian
#2 已发布: 2012/4/18 12:13:15
2,344个赞,共4,057个帖子。
组: Super Administrator
Hello.
Could you please send a file with an initial matrix to me or to post it on forum?
Regards.
#3 已发布: 2012/4/18 12:22:12
baldu
baldu
0个赞,共4个帖子。
Hello!
here is it:
http://www.file-upload.net/download-4282811/Matrix-Problems.sm.html
The main Problem is at the end: the solution deosnt work!
Thanks for you help!
Adrian
#4 已发布: 2012/4/18 12:59:19
325个赞和1个踩,共2,052个帖子。
Hello Adrian,
Just use the Numerical optimization for the last expression as well
[MATH=eng]gamma:B^{-1}*alfa[/MATH]
[MATH=eng]gamma=mat(0.059042586707757,0.109096474811639,0.142541413587456,0.154285714285714,0.142541413587457,0.109096474811639,0.059042586707757,7,1)[/MATH]
or use eval()
[MATH=eng]gamma:eval(B^{-1}*alfa)[/MATH]
[MATH=eng]gamma=mat(0.059042586707757,0.109096474811639,0.142541413587456,0.154285714285714,0.142541413587456,0.109096474811639,0.059042586707757,7,1)[/MATH]
In general, it is advisable to use Numerical optimization or eval() when matrix inversion is involved.
#5 已发布: 2012/12/6 05:24:23
jirijirkas
jirijirkas
0个赞,共3个帖子。
I want to ask you, if you find solution of the problem with inversion of the matrix, I have the same problem. From definition A*A^{-1}≡E and E have diagonal elements equal to one and other elements are equal to zero. But if I try A*A^{-1} in SMath, result is not identity matrix.
