1 Pages (8 items)
Numerical Integration of Data Set - Numerical Integration of Data Set - Messages
#1 Posted: 3/22/2017 5:22:47 AM
Is there an easy way to integrate a data set using the trapezoid rule, like the "trapz" function in matlab?
Also is there an easy way to find the centroid of this area?
I've attached a sample data set.
integration array.sm (3.05 KiB) downloaded 1271 time(s).
#2 Posted: 3/22/2017 7:55:36 AM
Ernesto 3/23/2017 9:18:00 PM
#3 Posted: 3/22/2017 1:14:35 PM
That's perfect!!
Thanks for your help!
#4 Posted: 3/22/2017 1:18:39 PM
or I can add original "trapz" function to the matlab plugin if you really need this.
#5 Posted: 3/22/2017 1:22:56 PM
Thanks but this is more than sufficient for my needs.
Regards.
Regards.
#6 Posted: 3/22/2017 3:12:56 PM
Ernesto,
Your data set is not impressive. As is: it represents no physical phenomenon.
The way I see it is otherwise ... it looks the linear junctions can only
represent derivatives of quadratic. It suggests a polynomial fit [offered].
Is it a piece of wood ? the fence around the yard ?
integration array [option].sm (22.17 KiB) downloaded 1102 time(s).
#7 Posted: 3/22/2017 3:29:50 PM
@Jean
It is horizontal soil pressure vs depth
#8 Posted: 3/23/2017 10:29:54 AM
Wrote@Jean
Thanks Ernesto, interesting.
You can complete and export your project,
in red at the end of the WS.
Polynomial fit QUARTIC Option.sm (26.24 KiB) downloaded 1289 time(s).
1 Pages (8 items)
