1 страниц (8 вхождений)
Numerical Integration of Data Set - Numerical Integration of Data Set - Сообщения
Is there an easy way to integrate a data set using the trapezoid rule, like the "trapz" function in matlab?
Also is there an easy way to find the centroid of this area?
I've attached a sample data set.
integration array.sm (3,05 КиБ) скачан 1135 раз(а).
Ernesto 23.03.2017 21:18:00
That's perfect!!
Thanks for your help!
or I can add original "trapz" function to the matlab plugin if you really need this.
Thanks but this is more than sufficient for my needs.
Regards.
Regards.
Ernesto,
Your data set is not impressive. As is: it represents no physical phenomenon.
The way I see it is otherwise ... it looks the linear junctions can only
represent derivatives of quadratic. It suggests a polynomial fit [offered].
Is it a piece of wood ? the fence around the yard ?
integration array [option].sm (22,17 КиБ) скачан 937 раз(а).
@Jean
It is horizontal soil pressure vs depth
Wrote@Jean
Thanks Ernesto, interesting.
You can complete and export your project,
in red at the end of the WS.
Polynomial fit QUARTIC Option.sm (26,24 КиБ) скачан 1135 раз(а).
