Temperature field
Temperature field - not straight line but one parabola - Messages
#1 Posted: 7/15/2023 3:32:54 AM
Valery Ochkov
Valery Ochkov
67 likes in 708 posts.
I am trying to plot a temperature field in a three layer wall. There is no problem with the outer layers. But there is a problem in the middle layer - there should be a parabola, not a straight line. How to draw this parabola in the simplest way - with one formula. I know the hard way.
Stenka-3-eng.sm (60.64 KiB) downloaded 1371 time(s).
#2 Posted: 7/15/2023 6:51:42 AM
Laurent Fournier
Laurent Fournier
9 likes in 66 posts.
There are so many splines and Bezier interpolations in this forum!
But I don't understand why the connecting line has to be a parabola, because inside one wall layer the parameters (conductance, permeability) are constant so you should have only straight lines. Unless you found a way to have a gradual mix of material!!!
#3 Posted: 7/15/2023 6:56:42 AM
Valery Ochkov
Valery Ochkov
In the outer walls, the thermal conductivity does not depend on temperature, but in the middle wall it depends linearly!
#4 Posted: 7/15/2023 7:17:49 AM
1,359 likes in 2,273 posts.
Don't know if that is the simplest solution.
Stenka-3-eng.sm (58.13 KiB) downloaded 1367 time(s).
Valery Ochkov 7/15/2023 7:25:00 AM
#5 Posted: 7/15/2023 7:26:46 AM
Valery Ochkov
Valery Ochkov
Fine!
And if the dependence of thermal conductivity on temperature is more complex, obtained, for example, through interpolation of discrete data. I would like to see an integral in the solution!
#6 Posted: 7/15/2023 7:32:04 AM
Version with mathcad block to collect the equations
Stenka-3-eng1.sm (59.5 KiB) downloaded 1391 time(s).
Valery Ochkov 7/15/2023 7:40:00 AM
#7 Posted: 7/15/2023 9:13:21 AM
1. Three layers linear from min(x).
2. NON-linear from experimental
... project done Mathsoft Collaboratory.
Make the first & third segments linear.
The two documents sanity checked Smath Solver 30405.
Cheers ... Jean.
Maths min(x),max(x).sm (22.23 KiB) downloaded 1373 time(s).
0Appendix_1 Thermal Insulation.sm (10.24 KiB) downloaded 1356 time(s).
#8 Posted: 7/16/2023 5:40:21 AM
Valery Ochkov
Valery Ochkov
One solution from Alan Stevens
Stenka-3-Alan.sm (60.35 KiB) downloaded 1343 time(s).
