Text Region Utilities Plugin
Text Region Utilities Plugin - Unable to install in 98.6128 - Messages
#1 Posted: 10/12/2016 8:09:25 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Unable to install Text Region Utilities plugin in 98.6128
Davide Carpi 10/12/2016 10:36:00 AM
#2 Posted: 10/12/2016 10:35:31 AM
thank you, I'll fix it ASAP
#3 Posted: 10/12/2016 11:39:21 AM
2,345 likes in 4,059 posts.
Davide, I've already fixed it by simple plug-in rebuild. Sorry, had no chance to inform you.
New version of the plug-in can be installed with no issues.
Davide Carpi 10/12/2016 12:30:00 PM
#4 Posted: 10/12/2016 12:12:15 PM
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey and Davide for the fix.
#5 Posted: 10/13/2016 12:45:45 AM
NDTM Amarasekera
NDTM Amarasekera
The "insert a toolbox" in Text Region Utilities Plug-in exibit erratic behaviour.
1. It shifts the selected text to a new position.
2. Apparantly, the empty lines between text lines are also considered as text?
3. Had to press "Apply" more than once to convert all selected text.
#6 Posted: 10/13/2016 5:55:24 AM
Thank you NDTM,
Fixing it, there were some changes in the API.
I'm not able to reproduce it; if you save the document with text regions and you load it again it still happens? If yes can you attach it here?
#7 Posted: 10/13/2016 10:24:20 AM
I don't understand what a "Tool Box" could be ?
Smath 5346 "Text Box" allows lot of decoration.
Decoration for a Web page presentation for instance.
As an Engineering working document: decoration is
too much, IMHO.
Each Shift/Enter adds blank line(s), an empty space
where to slide: images, graphs, foreign text ...
#8 Posted: 10/13/2016 10:52:19 AM
NDTM Amarasekera
NDTM Amarasekera
Thank you Davide!
The original file is attached; the problem still exists even after saving and re-opening.
Before Text Converter.sm (73.44 KiB) downloaded 1351 time(s).
Davide Carpi 10/13/2016 11:11:00 AM
#9 Posted: 10/13/2016 11:23:02 AM
Thank you, is exactly what I was thinking. If you select all (CTRL+A) you can see some empty text region, probably created with an UNDO action (because my bad coding in the converter feature). Should be no more an issue with the coming plugin update (but if existing you have to remove them manually).
I don't understand what a "Tool Box" could be?
Just a region that wraps some generic utilities related to the worksheet; when it will be possible I plan to move them in a toolbar (I'm working on it).
#10 Posted: 10/13/2016 1:56:56 PM
PLUGIN UPDATED
SMath Studio 0.98.6128
  • fixed issues related to API changes;
  • Text to Writer converter: history UNDO action managed correctly;
  • Text to Writer converter: fixed hyperlink conversion;
  • Batch hyperlinks: it is now possible to choose a path to investigate before launching the scan;
NDTM Amarasekera 10/13/2016 2:40:00 PM
#11 Posted: 10/13/2016 2:40:46 PM
NDTM Amarasekera
NDTM Amarasekera
Thank you Davide for the update.
Davide Carpi 10/13/2016 3:00:00 PM
#12 Posted: 12/15/2016 2:43:38 PM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
Plugin does not seem to work in latest SS 6179
#13 Posted: 12/15/2016 3:22:31 PM
Thank you Alex,
recompiled, try now.
sergio 12/16/2016 3:41:00 PM
#14 Posted: 12/16/2016 3:34:02 PM
Alexander O. Melnik
Alexander O. Melnik
works fine now, thanks!
