sqrt(squared units) not working anymore?
sqrt(squared units) not working anymore? - Messages
#1 Posted: 7/14/2014 11:34:46 AM
zapzapouch
zapzapouch
0 likes in 27 posts.
I had a worksheet that worked in the past, but now it doesn't, saying "operation cannot be performed with units", because it's sqrt(V^2)? But if I break it up into two steps it works:
resistor noise fail.sm (6.87 KiB) downloaded 1451 time(s).
#2 Posted: 7/14/2014 12:43:55 PM
Works for me with SMath 0.97.5301, but I see you are using 0.97.5154
Could you try to open your file with the latest Nightly build?
#3 Posted: 7/14/2014 12:52:13 PM
zapzapouch
zapzapouch
yes, it works in the Nightly build. thanks.
by the way, the email notification links never work. I always get
"There has been a serious error loading the forum. No further information is available.
Please contact the administrator if this message persists."
and have to find the topic manually
#4 Posted: 7/14/2014 12:57:40 PM
zapzapouch
zapzapouch
Actually, no, the original worksheet is not working, only the copy that I uploaded
Basic stuff.sm (11.77 KiB) downloaded 1401 time(s).
#5 Posted: 7/14/2014 1:23:39 PM
I've already seen this bug, sometimes comes to light...
when the SMath engine output unitary exponents on units, square root fails.
Refreshing the worksheet alternately works/doesn't works.
[EDIT] Added in the BTS: SS-177
