Weird Unit Conversion kg <> ton
Weird Unit Conversion kg <> ton - Messages
#1 Posted: 5/14/2018 5:27:41 AM
usamakhan
usamakhan
7 likes in 98 posts.
The question is simply clear ...its should be a matter of removing or adding x3 zeros
aMIR.sm (10.5 KiB) downloaded 1171 time(s).
#2 Posted: 5/14/2018 5:36:20 AM
Simple as the question
#3 Posted: 5/14/2018 6:00:37 AM
usamakhan
usamakhan
Thanks ...but can you tell me what is the wrong in this kg <> ton ...it should just reduce the power to 10 from 8 to 3 without changing the values
#4 Posted: 5/14/2018 6:04:53 AM
I missed it...
You have to use 't (metric ton) because 'ton here is the US "short ton"
#5 Posted: 5/14/2018 6:10:11 AM
usamakhan
usamakhan
I think its the problem ...I was expecting MetricTons
Problem solved
