Root or others solver
Root or others solver - Messages
#1 Posted: 3/11/2024 10:27:01 PM
Valery Ochkov
Valery Ochkov
67 likes in 713 posts.
See please the attach.
I cannot solve the system of equation by all the alpha values from 0 too 360 deg.
Is there the better solver for this task?
Or the better way for the solution.
Chebyshevs-Foot-Stepping-Machine.sm (179.44 KiB) downloaded 1522 time(s).
#2 Posted: 3/12/2024 12:29:43 AM
StvMath
StvMath
44 likes and 1 dislikes in 76 posts.
Your expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0).
Chebyshevs-Foot-Stepping-Machine_b.sm (176.63 KiB) downloaded 1481 time(s).
Valery Ochkov 3/12/2024 3:37:00 PM
#3 Posted: 3/12/2024 2:12:27 AM
Valery Ochkov
Valery Ochkov
I'm sorry, but this is not correct. The coordinates of point 4 should depend on the length L.04.
#4 Posted: 3/12/2024 3:50:39 AM
StvMath
StvMath
Because L.04 is the same length as L.03 it does, in fact, implicitly depend on L.04. Check the two files for a few angles and you will see that they give the same results (except that my file works for all angles).
Basically, I've used the fact that (x4 + x3)/2 = x0 and (y4 + y3)/2 = y0.
If L.04 and L.03 are different lengths a weighted average would be used, i.e. (L.03*x4 + L.04*x3)/(L.03 + L.04) = x0 and (L.03*y4 + L.04*y3)/(L.03 + L.04) = y0.
#5 Posted: 3/12/2024 3:37:09 PM
Valery Ochkov
Valery Ochkov
Thanks!
See? please the attach
Chebyshevs-Foot-Stepping-Machine.sm (178.3 KiB) downloaded 1487 time(s).
Now I will try to plot the trac of the point 4.
Help me please.
#6 Posted: 3/12/2024 7:47:02 PM
StvMath
StvMath
Thanks!
Help me please.
See attached (but I'll leave you to do any animation!).
Chebyshevs-Foot-Stepping-Machine_c.sm (176.97 KiB) downloaded 1488 time(s).
Valery Ochkov 3/12/2024 10:08:00 PM
#7 Posted: 3/12/2024 10:07:28 PM
Valery Ochkov
Valery Ochkov
Thanks!
See please my little editing
Chebyshevs-Foot-Stepping-Machine-Trace.sm (177.86 KiB) downloaded 1481 time(s).
One question
See please
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (178.15 KiB) downloaded 1509 time(s).
and tell me - it is my or SMath bug with the plot?
#8 Posted: 3/13/2024 12:19:48 AM
StvMath
StvMath
Thanks!
One question
See please
?? I don't see anything wrong with the plot!
#9 Posted: 3/13/2024 1:19:04 AM
Valery Ochkov
Valery Ochkov
#10 Posted: 3/13/2024 1:27:07 AM
StvMath
StvMath
See please
Oh!, I see! Just double-click on the plot, select Traces, then for each of Traces 2 through 6 select Symbol style, then Circle.
Valery Ochkov 3/13/2024 2:28:00 PM
#11 Posted: 3/13/2024 1:30:06 AM
Valery Ochkov
Valery Ochkov
See please
it's one bug?
#12 Posted: 3/13/2024 1:43:29 AM
Valery Ochkov
Valery Ochkov
About this task see please pp 23-34 here
The chapter 8 from the book
2^5 Problems for STEM Education
Now I am writing same chapter for the SMath book.
For me will be interesting your remarks.
#13 Posted: 3/13/2024 3:06:27 AM
Valery Ochkov
Valery Ochkov
See the animation here
tchebyshev plantigrade
#14 Posted: 3/13/2024 1:21:14 PM
1,558 likes in 1,868 posts.
Я суслика не вижу, можно поконкретнее описать и показать что не так с компонентом X-Y Plot?
Valery Ochkov 3/13/2024 2:27:00 PM
#15 Posted: 3/13/2024 1:34:28 PM
Valery Ochkov
Valery Ochkov
Спасибо, Вячеслав, что откликнулся.
Суслик вот в чем.
На этом графике в его аргументе записана система с перечислением кривых.
Chebyshevs-Foot-Stepping-Machine-Trace.sm (177.86 KiB) downloaded 1476 time(s).
Все ОК.
Затем для компактности документа я захотел использовать переменную Plot.
Формат графика сбился.
См. картинку наверху и
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (178.15 KiB) downloaded 1470 time(s).
#16 Posted: 3/13/2024 1:57:59 PM
Я попробовал и мне трудно было повторить условия возникновения такого поведения.
Настройки не должны слетать, если количество графиков между пересчётами документа не меняется. Если возникла ошибка во время построения одного из графиков, то настройки сохраняются. Если вы изменили количество отображаемых графиков (а оно определяется только во время пересчёта), то остальные графики "забываются".
Рекомендация: отключить автоматический пересчёт на время подобных манипуляций.
Я подумаю о добавлении опции - сохранять настройки между пересчётами не только для исключительных ситуаций. Возможно была причина, по которой я оставил такое поведение.
#17 Posted: 3/13/2024 2:26:57 PM
Valery Ochkov
Valery Ochkov
Спасибо!
Заодно подумайте и о:
1. После ввода выражения кривой видно весь график. А то приходится долго крутить мышкой.
2. Возможность фиксирования разброса графика так, чтобы его мышкой нельзя было менять.
#18 Posted: 3/15/2024 12:23:36 PM
grelkin2
grelkin2
14 likes in 67 posts.
Я написал статью о лямбда-механизе Чебышёва. Smath почему-то анимацию не воспроизводит. Могу ответить на вопросы по вычислениям и системе. Решение получено при помощи метода Драгилева.
http://razdvizh.site/chebl
#19 Posted: 3/15/2024 2:14:16 PM
Valery Ochkov
Valery Ochkov
Спасибо за ценную информацию, но ссылка не работает
#20 Posted: 3/16/2024 6:18:38 PM
Valery Ochkov
Valery Ochkov
I have change the roots function on the Newton function.
Now we can change variables r, L,01, L.02 etc and no problem!
16-4-Chebyshevs-Foot-Stepping-Machine-Trace-Newton.sm (930.96 KiB) downloaded 1597 time(s).
