Root or others solver
Root or others solver - Сообщения
#1 Опубликовано: 11.03.2024 22:27:01
Valery Ochkov
Valery Ochkov
See please the attach.
I cannot solve the system of equation by all the alpha values from 0 too 360 deg.
Is there the better solver for this task?
Or the better way for the solution.
Chebyshevs-Foot-Stepping-Machine.sm (179,44 КиБ) скачан 1522 раз(а).
#2 Опубликовано: 12.03.2024 00:29:43
StvMath
StvMath
44 сообщений из 76 понравились и 1 не понравились пользователям.
Your expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0).
Chebyshevs-Foot-Stepping-Machine_b.sm (176,63 КиБ) скачан 1481 раз(а).
Valery Ochkov 12.03.2024 15:37:00
#3 Опубликовано: 12.03.2024 02:12:27
Valery Ochkov
Valery Ochkov
I'm sorry, but this is not correct. The coordinates of point 4 should depend on the length L.04.
#4 Опубликовано: 12.03.2024 03:50:39
StvMath
StvMath
Because L.04 is the same length as L.03 it does, in fact, implicitly depend on L.04. Check the two files for a few angles and you will see that they give the same results (except that my file works for all angles).
Basically, I've used the fact that (x4 + x3)/2 = x0 and (y4 + y3)/2 = y0.
If L.04 and L.03 are different lengths a weighted average would be used, i.e. (L.03*x4 + L.04*x3)/(L.03 + L.04) = x0 and (L.03*y4 + L.04*y3)/(L.03 + L.04) = y0.
#5 Опубликовано: 12.03.2024 15:37:09
Valery Ochkov
Valery Ochkov
Thanks!
See? please the attach
Chebyshevs-Foot-Stepping-Machine.sm (178,3 КиБ) скачан 1487 раз(а).
Now I will try to plot the trac of the point 4.
Help me please.
#6 Опубликовано: 12.03.2024 19:47:02
StvMath
StvMath
Thanks!
Help me please.
See attached (but I'll leave you to do any animation!).
Chebyshevs-Foot-Stepping-Machine_c.sm (176,97 КиБ) скачан 1488 раз(а).
Valery Ochkov 12.03.2024 22:08:00
#7 Опубликовано: 12.03.2024 22:07:28
Valery Ochkov
Valery Ochkov
Thanks!
See please my little editing
Chebyshevs-Foot-Stepping-Machine-Trace.sm (177,86 КиБ) скачан 1481 раз(а).
One question
See please
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (178,15 КиБ) скачан 1509 раз(а).
and tell me - it is my or SMath bug with the plot?
#8 Опубликовано: 13.03.2024 00:19:48
StvMath
StvMath
Thanks!
One question
See please
?? I don't see anything wrong with the plot!
#9 Опубликовано: 13.03.2024 01:19:04
Valery Ochkov
Valery Ochkov
#10 Опубликовано: 13.03.2024 01:27:07
StvMath
StvMath
See please
Oh!, I see! Just double-click on the plot, select Traces, then for each of Traces 2 through 6 select Symbol style, then Circle.
Valery Ochkov 13.03.2024 14:28:00
#11 Опубликовано: 13.03.2024 01:30:06
Valery Ochkov
Valery Ochkov
See please
it's one bug?
#12 Опубликовано: 13.03.2024 01:43:29
Valery Ochkov
Valery Ochkov
About this task see please pp 23-34 here
The chapter 8 from the book
2^5 Problems for STEM Education
Now I am writing same chapter for the SMath book.
For me will be interesting your remarks.
#13 Опубликовано: 13.03.2024 03:06:27
Valery Ochkov
Valery Ochkov
See the animation here
tchebyshev plantigrade
#14 Опубликовано: 13.03.2024 13:21:14
Я суслика не вижу, можно поконкретнее описать и показать что не так с компонентом X-Y Plot?
Valery Ochkov 13.03.2024 14:27:00
#15 Опубликовано: 13.03.2024 13:34:28
Valery Ochkov
Valery Ochkov
Спасибо, Вячеслав, что откликнулся.
Суслик вот в чем.
На этом графике в его аргументе записана система с перечислением кривых.
Chebyshevs-Foot-Stepping-Machine-Trace.sm (177,86 КиБ) скачан 1476 раз(а).
Все ОК.
Затем для компактности документа я захотел использовать переменную Plot.
Формат графика сбился.
См. картинку наверху и
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (178,15 КиБ) скачан 1470 раз(а).
#16 Опубликовано: 13.03.2024 13:57:59
Я попробовал и мне трудно было повторить условия возникновения такого поведения.
Настройки не должны слетать, если количество графиков между пересчётами документа не меняется. Если возникла ошибка во время построения одного из графиков, то настройки сохраняются. Если вы изменили количество отображаемых графиков (а оно определяется только во время пересчёта), то остальные графики "забываются".
Рекомендация: отключить автоматический пересчёт на время подобных манипуляций.
Я подумаю о добавлении опции - сохранять настройки между пересчётами не только для исключительных ситуаций. Возможно была причина, по которой я оставил такое поведение.
#17 Опубликовано: 13.03.2024 14:26:57
Valery Ochkov
Valery Ochkov
Спасибо!
Заодно подумайте и о:
1. После ввода выражения кривой видно весь график. А то приходится долго крутить мышкой.
2. Возможность фиксирования разброса графика так, чтобы его мышкой нельзя было менять.
#18 Опубликовано: 15.03.2024 12:23:36
grelkin2
grelkin2
14 сообщений из 67 понравились пользователям.
Я написал статью о лямбда-механизе Чебышёва. Smath почему-то анимацию не воспроизводит. Могу ответить на вопросы по вычислениям и системе. Решение получено при помощи метода Драгилева.
http://razdvizh.site/chebl
#19 Опубликовано: 15.03.2024 14:14:16
Valery Ochkov
Valery Ochkov
Спасибо за ценную информацию, но ссылка не работает
#20 Опубликовано: 16.03.2024 18:18:38
Valery Ochkov
Valery Ochkov
I have change the roots function on the Newton function.
Now we can change variables r, L,01, L.02 etc and no problem!
16-4-Chebyshevs-Foot-Stepping-Machine-Trace-Newton.sm (930,96 КиБ) скачан 1597 раз(а).
