Function from plot
Function from plot - Messages
#1 Posted: 6/6/2023 8:19:33 AM
Valery Ochkov
Valery Ochkov
67 likes in 716 posts.
How can I get a function from this plot?
#2 Posted: 6/6/2023 8:59:59 AM
How can I get a function from this plot ?
1. Probably from the expensive digitizer suggested by Richard [Mathsoft Collaboratory]
2. Piecewise from Tracer.
3. Try Mathsoft digitizer.
4. Smath difficult
At this point from the collected data set, fit a model function.
Cheers ... Jean.
Valery Ochkov 6/6/2023 10:24:00 AM
#3 Posted: 6/6/2023 10:05:20 AM
Brian Runagle
Brian Runagle
13 likes in 27 posts.
Does this help?
Graphing.pdf (164.86 KiB) downloaded 1557 time(s).
Brian
#4 Posted: 6/6/2023 10:15:02 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 181 posts.
Greetings,
How can I get a function from this plot? 🖼
That is a straight line on a semi-log graph; you can reference this handout: https://inside.mines.edu/~epoeter/_GW/LAB/EquationsOfStraightLinesOnDifferentTypesGraphPaper.pdf
Per this handout, your equation should be
y = b + m*log(x)
where:
  • m = difference in y over one log cycle of x
  • b = y value corresponding to x=1
May this be of Good Help;
#5 Posted: 6/6/2023 12:44:34 PM
1,139 likes in 1,805 posts.
Hi. You can try this post Approximation of a functional curve in a digital image or this other one: Embedding images into a plot
Вячеслав Мезенцев 6/6/2023 2:16:00 PM, Valery Ochkov 6/6/2023 1:45:00 PM
#6 Posted: 6/6/2023 2:19:52 PM
Hello Valery,
some Smath digitizing utilities
Cheers, Jean.
Digitize Tracer 15.sm (28.83 KiB) downloaded 1404 time(s).
Digitize OVNI Copy.sm (69.15 KiB) downloaded 1387 time(s).
Digitize Contour Isocurve Himmelblau Copy.sm (106.67 KiB) downloaded 1445 time(s).
Digitize Curve.sm (295.86 KiB) downloaded 1378 time(s).
Digitize Contour.sm (829.05 KiB) downloaded 1461 time(s).
Digitize Clean_Strip_Smooth.sm (1.76 MiB) downloaded 1498 time(s).
#7 Posted: 6/6/2023 3:29:30 PM
... this Himmelblau has resident Gray matrix.
Digitize Contour Isocurve Himmelblau Copy.sm (107.19 KiB) downloaded 1449 time(s).
Valery Ochkov 6/7/2023 1:02:00 AM
#8 Posted: 6/6/2023 5:11:16 PM
Hi. Hope this helps.
Modeling a functional curve in a digital image.pdf (860.39 KiB) downloaded 929 time(s).
Modeling a functional curve in a digital image.sm (1 MiB) downloaded 1510 time(s).
3 users liked this post
Valery Ochkov 6/7/2023 1:02:00 AM, sergio 6/7/2023 6:34:00 AM, darlbeck 6/7/2023 2:59:00 PM
