Function from plot
Function from plot - Сообщения
#1 Опубликовано: 06.06.2023 08:19:33
Valery Ochkov
Valery Ochkov
67 сообщений из 708 понравились пользователям.
How can I get a function from this plot?
#2 Опубликовано: 06.06.2023 08:59:59
How can I get a function from this plot ?
1. Probably from the expensive digitizer suggested by Richard [Mathsoft Collaboratory]
2. Piecewise from Tracer.
3. Try Mathsoft digitizer.
4. Smath difficult
At this point from the collected data set, fit a model function.
Cheers ... Jean.
Valery Ochkov 06.06.2023 10:24:00
#3 Опубликовано: 06.06.2023 10:05:20
Brian Runagle
Brian Runagle
13 сообщений из 27 понравились пользователям.
Does this help?
Graphing.pdf (164,86 КиБ) скачан 1501 раз(а).
Brian
#4 Опубликовано: 06.06.2023 10:15:02
⚜ Kenny Lemens, P.E. ᵂᴵ
85 сообщений из 181 понравились пользователям.
Greetings,
How can I get a function from this plot? 🖼
That is a straight line on a semi-log graph; you can reference this handout: https://inside.mines.edu/~epoeter/_GW/LAB/EquationsOfStraightLinesOnDifferentTypesGraphPaper.pdf
Per this handout, your equation should be
y = b + m*log(x)
where:
  • m = difference in y over one log cycle of x
  • b = y value corresponding to x=1
May this be of Good Help;
#5 Опубликовано: 06.06.2023 12:44:34
Hi. You can try this post Approximation of a functional curve in a digital image or this other one: Embedding images into a plot
Вячеслав Мезенцев 06.06.2023 14:16:00, Valery Ochkov 06.06.2023 13:45:00
#6 Опубликовано: 06.06.2023 14:19:52
Hello Valery,
some Smath digitizing utilities
Cheers, Jean.
Digitize Tracer 15.sm (28,83 КиБ) скачан 1339 раз(а).
Digitize OVNI Copy.sm (69,15 КиБ) скачан 1341 раз(а).
Digitize Contour Isocurve Himmelblau Copy.sm (106,67 КиБ) скачан 1406 раз(а).
Digitize Curve.sm (295,86 КиБ) скачан 1318 раз(а).
Digitize Contour.sm (829,05 КиБ) скачан 1404 раз(а).
Digitize Clean_Strip_Smooth.sm (1,76 МиБ) скачан 1443 раз(а).
#7 Опубликовано: 06.06.2023 15:29:30
... this Himmelblau has resident Gray matrix.
Digitize Contour Isocurve Himmelblau Copy.sm (107,19 КиБ) скачан 1395 раз(а).
Valery Ochkov 07.06.2023 01:02:00
#8 Опубликовано: 06.06.2023 17:11:16
Hi. Hope this helps.
Modeling a functional curve in a digital image.pdf (860,39 КиБ) скачан 883 раз(а).
Modeling a functional curve in a digital image.sm (1 МиБ) скачан 1461 раз(а).
Valery Ochkov 07.06.2023 01:02:00, sergio 07.06.2023 06:34:00, darlbeck 07.06.2023 14:59:00
