Stable: SMath Studio 0.99.6884 (06 November 2018)
Stable: SMath Studio 0.99.6884 (06 November 2018) - Messages
#1 Posted: 11/6/2018 3:39:16 PM
2,343 likes in 4,044 posts.
List of changes (between 0.99.6858 and 0.99.6884 versions)
Improvements
  • Added support for Header/Footer (see Insert > Header/Footer menu items or use doubleclick on Header/Footer area to activate editing; press ESC or doubleclick on page content to return back);
  • Implemented support for Fields (auto-fields) inside MathRegion (see Insert > Field... dialog);
  • Added ability to Fill background image to the page bounds;
  • Background image can now be shown in full page size;
  • MathRegions consists with single variable name contains special symbols automatically switches cursor to Special Chars mode on focus;
  • Functions dialog improved (added filter by plug-in and quick search box);
  • Background dialog improved to show currently chosen image on dialog open.
Corrections
  • Fixed issue happens on drawing cursor after space symbol in MathRegion;
  • Incorrect pages numbers used in Insert Background dialog fixed for Pages layout mode;
  • Fixed observation happens on inserting operator inside of the variable name which contains special symbols;
  • SS-3567: Saving of worksheets with protected collapsed Areas fixed;
  • Fixed critical observation happens on deleting unit inserted by Dynamic Assistance;
  • SS-3569, SS-3570: Moving of collapsed Area regions not allowed now (until better solution is found);
  • Slow performance on first Dynamic Assistence list call fixed (happened in case of many plug-ins installed);
  • SS-3574: Support for the fallback font family added;
  • Fixed app crash on plug-in installation failed when no valid *.dll is found;
  • Fixed zooming related issues;
  • Fixed error happens when Worksheet debugging activated and there is a variable with 'value' name specified;
  • SS-3575: Fixed error of using fractional power;
  • Application start failure under Mono runtime fixed;
  • Fixed issues when Dynamic Assistance list does not show built-in items;
  • Environment specific rendering issues of the Dynamic Assistance list fixed;
  • Accuracy of work with complex numbers improved;
  • Scrollbar bookmark related to current cursor location corrected to always show actual cursor position;
  • Work with high-quality backgrounds optimized (overall performance improved).
Miscellaneous
  • Refactoring;
  • Interface translations updated.
Download
SMathStudioDesktop.0_99_6884.Mono.tar.gz (1.35 MiB) downloaded 5661 time(s).
SMathStudioDesktop.0_99_6884.Setup.msi (2.23 MiB) downloaded 43994 time(s).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
12 users liked this post
Arie 11/6/2018 3:52:00 PM, Fridel Selitsky 11/6/2018 4:30:00 PM, Davide Carpi 11/6/2018 5:08:00 PM, sergio 11/6/2018 5:57:00 PM, bdrunagle 11/6/2018 6:39:00 PM, NDTM Amarasekera 11/6/2018 10:37:00 PM, Вячеслав Мезенцев 11/7/2018 3:13:00 AM, Igor Skarine 11/7/2018 12:51:00 PM, IVR 11/9/2018 12:53:00 PM, Serg 11/13/2018 4:30:00 AM, Василий Николаевич Храмушин 11/17/2018 3:46:00 PM, Mikka 11/20/2018 7:42:00 AM
#2 Posted: 11/6/2018 5:07:50 PM
4 users liked this post
IVR 11/9/2018 12:54:00 PM, Andrey Ivashov 11/6/2018 6:27:00 PM, Вячеслав Мезенцев 11/7/2018 2:42:00 AM, NDTM Amarasekera 11/7/2018 5:50:00 AM
#3 Posted: 11/9/2018 5:44:02 PM
dio pants
dio pants
16 likes in 180 posts.
Are there any plugin incompatibilities known which work and which dont work?
#4 Posted: 11/10/2018 2:24:21 PM
Brian Runagle
Brian Runagle
13 likes in 27 posts.
In response to Davide's documentation post, the first time I tried to open the file on my Windows 7 PC the topics on the left-hand pane displayed correctly but the right-hand pane was blank.
In case anyone else has the same problem, I found that it displays correctly when saved in the Users area - C:\Users\'username'\ - and opened from there.
I think this must be a Windows 'Security' feature.
Brian
#5 Posted: 11/10/2018 3:00:01 PM
Brian
Yes, it is a security feature of Windows.
here in the accepted answer you can see different approaches to solve it.
bdrunagle 11/10/2018 4:21:00 PM
#6 Posted: 11/18/2018 6:23:42 AM
598 likes in 1,380 posts.
I can't copy or cut and paste any region (text, writer, image, etc) from header/footer.
It is just can't be pasted to anywhere in Smath.
Have a nice sunday folks,
#7 Posted: 11/18/2018 9:03:08 AM
Can't understand what you mean by text, writer, image from header/footer
#8 Posted: 11/18/2018 9:45:58 AM
because you are on way outdated version (6179) of smath. I am talking about 6884. there is a new functionality which is introduced in 6873, header/footer areas.
#9 Posted: 11/18/2018 12:41:37 PM
... what is it supposed to do, or what did you expect it would do ?
You let suppose it would take an image in either or both header/footer ?
#10 Posted: 11/18/2018 5:04:04 PM
I will try to explain, from the beginning.
There are header and footer areas for MS Office Word, Libreoffice Writer, LaTeX, etc for decades.
You know, some reports or calculations are not just one or two page.
Header and footer areas helps people to maintain some crucial information for the multiple paged reports they assembled.
Project name, company logo, page number, etc. Please don't mention the one-lined "&[DATE]&[TIME] &[PAGENUM]/&[TOTAL]" thing. It is not the same thing.
So our beloved Smath has this helpful functionality, thanks to Andrey.
So the problem is, you can directly write into header or footer in Smath. You can even paste company logo, writer regions, text regions.
You can delete these mentioned regions in header/footer areas too. But you can not copy these regions.
You can not copy to another Smath File's header/footer area, even to Smath calculation area.
Simply you can not copy the information in header/footer area to anywhere.
Regards.
#11 Posted: 11/18/2018 5:33:17 PM
I will try to explain ...
Thanks: I know about those things [header/footer]
In Mathcad, I have included a small RGB logo in either one
but so small, that the visitor who demanded just abandoned.
Just a little rainbow was of no interest either !
Does it work w/o copy/paste ?
Wait and see ...
#12 Posted: 11/20/2018 5:01:56 AM
kadpeter
kadpeter
0 likes in 10 posts.
I've found an issue in SMath.
I made more SMath document with 100% Windows Custom DPI. Month ago I changed my monitor and I had to change Windows Custom DPI to 125%. Unfortunatelly I can't now print my old documents, because the right side of the documents located on the nonprintable area yet.
I use Windows7, I tested 100%, 125% and 150%.
This screenshot was created with 125% Windows Custom DPI:
Here is a test document:
Test_width.sm (1.97 KiB) downloaded 1780 time(s).
There is an other small issue too. I have to click two times to Print icon in printer selection page if I would like to print. First time nothing happens.
Peter Kaderasz
#13 Posted: 11/20/2018 1:36:46 PM
Hello Peter.
Yes, I'm already informed about this issue. Working on it right now.
Sorry for inconvenience.
Davide Carpi 11/20/2018 3:20:00 PM
#14 Posted: 11/25/2018 1:22:29 AM
Jose Carlo Mendoza
Jose Carlo Mendoza
7 likes in 14 posts.
I have a problem with strings in smath worksheet. It turns out that some characters are converted if input string matches some hexadecimal characters..i don't know if this is a feature..but it transforms some of my smath documents specially with strings as FilePaths..please see attached snapshot.
#15 Posted: 12/11/2018 1:08:00 PM
1,359 likes in 2,273 posts.
Portable distribution with plugins updated to current stable build (6884). See signature for the link.
Radovan Omorjan 12/12/2018 8:59:00 AM, Andrey Ivashov 12/12/2018 9:34:00 AM, sergio 12/11/2018 3:17:00 PM, Вячеслав Мезенцев 12/12/2018 8:51:00 AM
