Stable: SMath Studio 0.99.6884 (06 November 2018)
Stable: SMath Studio 0.99.6884 (06 November 2018) - Сообщения
#1 Опубликовано: 06.11.2018 15:39:16
Группа: Super Administrator
Список изменений (между версиями 0.99.6858 и 0.99.6884)
Исправления
  • Work with high-quality backgrounds optimized (overall performance improved).
Разное
  • Interface translations updated;
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_6884.Mono.tar.gz (1,35 МиБ) скачан 6003 раз(а).
SMathStudioDesktop.0_99_6884.Setup.msi (2,23 МиБ) скачан 44507 раз(а).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
12 пользователям понравился этот пост
Arie 06.11.2018 15:52:00, Fridel Selitsky 06.11.2018 16:30:00, Davide Carpi 06.11.2018 17:08:00, sergio 06.11.2018 17:57:00, bdrunagle 06.11.2018 18:39:00, NDTM Amarasekera 06.11.2018 22:37:00, Вячеслав Мезенцев 07.11.2018 03:13:00, Igor Skarine 07.11.2018 12:51:00, IVR 09.11.2018 12:53:00, Serg 13.11.2018 04:30:00, Василий Николаевич Храмушин 17.11.2018 15:46:00, Mikka 20.11.2018 07:42:00
#2 Опубликовано: 06.11.2018 17:07:50
IVR 09.11.2018 12:54:00, Andrey Ivashov 06.11.2018 18:27:00, Вячеслав Мезенцев 07.11.2018 02:42:00, NDTM Amarasekera 07.11.2018 05:50:00
#3 Опубликовано: 09.11.2018 17:44:02
dio pants
dio pants
16 сообщений из 180 понравились пользователям.
Are there any plugin incompatibilities known which work and which dont work?
#4 Опубликовано: 10.11.2018 14:24:21
Brian Runagle
Brian Runagle
13 сообщений из 27 понравились пользователям.
In response to Davide's documentation post, the first time I tried to open the file on my Windows 7 PC the topics on the left-hand pane displayed correctly but the right-hand pane was blank.
In case anyone else has the same problem, I found that it displays correctly when saved in the Users area - C:\Users\'username'\ - and opened from there.
I think this must be a Windows 'Security' feature.
Brian
#5 Опубликовано: 10.11.2018 15:00:01
Brian
Yes, it is a security feature of Windows.
here in the accepted answer you can see different approaches to solve it.
bdrunagle 10.11.2018 16:21:00
#6 Опубликовано: 18.11.2018 06:23:42
I can't copy or cut and paste any region (text, writer, image, etc) from header/footer.
It is just can't be pasted to anywhere in Smath.
Have a nice sunday folks,
#7 Опубликовано: 18.11.2018 09:03:08
Can't understand what you mean by text, writer, image from header/footer
#8 Опубликовано: 18.11.2018 09:45:58
because you are on way outdated version (6179) of smath. I am talking about 6884. there is a new functionality which is introduced in 6873, header/footer areas.
#9 Опубликовано: 18.11.2018 12:41:37
... what is it supposed to do, or what did you expect it would do ?
You let suppose it would take an image in either or both header/footer ?
#10 Опубликовано: 18.11.2018 17:04:04
I will try to explain, from the beginning.
There are header and footer areas for MS Office Word, Libreoffice Writer, LaTeX, etc for decades.
You know, some reports or calculations are not just one or two page.
Header and footer areas helps people to maintain some crucial information for the multiple paged reports they assembled.
Project name, company logo, page number, etc. Please don't mention the one-lined "&[DATE]&[TIME] &[PAGENUM]/&[TOTAL]" thing. It is not the same thing.
So our beloved Smath has this helpful functionality, thanks to Andrey.
So the problem is, you can directly write into header or footer in Smath. You can even paste company logo, writer regions, text regions.
You can delete these mentioned regions in header/footer areas too. But you can not copy these regions.
You can not copy to another Smath File's header/footer area, even to Smath calculation area.
Simply you can not copy the information in header/footer area to anywhere.
Regards.
#11 Опубликовано: 18.11.2018 17:33:17
I will try to explain ...
Thanks: I know about those things [header/footer]
In Mathcad, I have included a small RGB logo in either one
but so small, that the visitor who demanded just abandoned.
Just a little rainbow was of no interest either !
Does it work w/o copy/paste ?
Wait and see ...
#12 Опубликовано: 20.11.2018 05:01:56
kadpeter
kadpeter
0 сообщений из 10 понравились пользователям.
I've found an issue in SMath.
I made more SMath document with 100% Windows Custom DPI. Month ago I changed my monitor and I had to change Windows Custom DPI to 125%. Unfortunatelly I can't now print my old documents, because the right side of the documents located on the nonprintable area yet.
I use Windows7, I tested 100%, 125% and 150%.
This screenshot was created with 125% Windows Custom DPI:
Here is a test document:
Test_width.sm (1,97 КиБ) скачан 1816 раз(а).
There is an other small issue too. I have to click two times to Print icon in printer selection page if I would like to print. First time nothing happens.
Peter Kaderasz
#13 Опубликовано: 20.11.2018 13:36:46
Hello Peter.
Yes, I'm already informed about this issue. Working on it right now.
Sorry for inconvenience.
Davide Carpi 20.11.2018 15:20:00
#14 Опубликовано: 25.11.2018 01:22:29
Jose Carlo Mendoza
Jose Carlo Mendoza
7 сообщений из 14 понравились пользователям.
I have a problem with strings in smath worksheet. It turns out that some characters are converted if input string matches some hexadecimal characters..i don't know if this is a feature..but it transforms some of my smath documents specially with strings as FilePaths..please see attached snapshot.
#15 Опубликовано: 11.12.2018 13:08:00
Portable distribution with plugins updated to current stable build (6884). See signature for the link.
Radovan Omorjan 12.12.2018 08:59:00, Andrey Ivashov 12.12.2018 09:34:00, sergio 11.12.2018 15:17:00, Вячеслав Мезенцев 12.12.2018 08:51:00
