Reset/Remove Variable
Reset/Remove Variable - Variable delete - Messages
#1 Posted: 10/16/2012 1:24:00 PM
Topsi
Topsi
0 likes in 8 posts.
Dear members,
in often times I need the variable x . Then in next time I make
in Example a differential of Function, and x is rember of value or defition.
In mathCad I remove a variable with x:=x.
What can I do in SMath ?
So many thanks for help.
Topsi
#2 Posted: 10/16/2012 1:39:01 PM
1,443 likes in 2,935 posts.
Dear members,
Topsi
Hi Topsi,
AFAIK the only way it's to use a 2nd empty variable.
f.e.
[LIVE width=170 height=157]http://smath.info/live/?file=4019[/LIVE]
regards,
w3b5urf3r
#3 Posted: 10/16/2012 4:02:58 PM
Topsi
Topsi
0 likes in 8 posts.
Hello w3burf3r,
thanks for your help, but I can't type the symbol # in place holder.
A free new variable, that will be good. But in the teaching I will
have always the x - variable.
Have you a little helb for this new question.
Thanks for help
Topsi
#4 Posted: 10/16/2012 6:11:18 PM
Hi
I know, it's not a wonderful solution... I've already attempted to create a Clear() function inside a plugin - nothing to do
You can post a Feature request in the forum, IMHO would be an useful feature
As for the # character, you must write at least one letter and then you can write the # before the first character (I don't know if this is a bug or a feature).
regards,
w3b5urf3r
#5 Posted: 10/17/2012 10:02:17 AM
Oscar Campo
Oscar Campo
135 likes in 309 posts.
An easy way to remove a variable is use another variable but undefined:
ClearVar
So, you must the "clean" variable undefined.
Oscar
#6 Posted: 10/17/2012 12:41:31 PM
1,355 likes in 2,271 posts.
ClearVar
Sorry, does not work here. Clean removal would make X appear as result in the mapUnknown function from the NonLinearSolvers plugin.(see here).
Best regards, Martin Kraska
#7 Posted: 10/17/2012 3:46:32 PM
Topsi
Topsi
0 likes in 8 posts.
All helpers,
many thanks,
sorry, but my problem ist not lost. That is very trouble of SMath that I can't
remove a variable. See what I meen:
x:=3
x=3
x:=clean
x=
f(x):=x³
d
- f(x)=3 clean²
dx
that is very bad.
I think in the next version it will be.
So if anywhere help me than I give thanks bevor.
Topsi
#8 Posted: 10/19/2012 8:23:04 AM
Oscar Campo
Oscar Campo
I see...
So I join the request for a clear() function: http://en.smath.info/forum/yaf_postst1576_clear---function.aspx
