1 Pages (12 items)
How to use the solve function in this task - Messages
#1 Posted: 6/2/2024 8:33:38 PM
3-2-CoolProp-Solve.sm (46.14 KiB) downloaded 1637 time(s).
#3 Posted: 6/2/2024 11:27:35 PM
Thanks,
send please the sm-file with the solution
#4 Posted: 6/3/2024 12:42:55 AM
The problem, as you formulated, seems as not having a solution in real numbers, in order to be solved with the solve routine.
I'm sorry but I have no time to reformulate your problem.
If you intend to solve it numerically, try to check the continuity of the function and the fact that in the range you look for solution there is at least one change of the function value sign.
Valery Ochkov 6/3/2024 12:59:00 AM
#5 Posted: 6/3/2024 1:46:02 AM
The problem as stated in the opening post, actually has a solution in the given range.
Yet, I don't see an alternative to using brute force to tame the coolprop function: sampling and interpolation.
Valery Ochkov 6/3/2024 1:50:00 AM
#6 Posted: 6/3/2024 2:12:41 AM
Hi. The guess values, in this case the range, are part of the solution, this means that you must know where the numerical procedure works fine. In this case the interval 1 MPa ... 6 MPa.
3-2-CoolProp-Solve.sm (49.75 KiB) downloaded 1623 time(s).
#7 Posted: 6/3/2024 10:47:51 AM
Thanks, Martin and Alvaro
See please the problem in attach
Fireless-Locomotive.sm (882.15 KiB) downloaded 1658 time(s).
PS
Alvaro!
And what about the book?
PS
Alvaro!
#8 Posted: 6/3/2024 12:58:22 PM
Hi Valery. This could be an option.
Fireless-Locomotive.sm (915.8 KiB) downloaded 1655 time(s).
I'm pretty busy right now! Sorry.
Wrote...
PS
Alvaro!
Valery Ochkov 6/3/2024 4:04:00 PM
#9 Posted: 6/3/2024 4:29:42 PM
It works! By p.0=240 atm
Fireless-Locomotive.sm (882.15 KiB) downloaded 1715 time(s).
But by p.0=140 atm ---???
Alvaro>
Check please 1-2-3 chapters.
My student from Cuba is waiting for it!
Alvaro>
#10 Posted: 6/5/2024 9:16:15 PM
Wrote... Check please 1-2-3 chapters.
Hi Valery. I find it quite inappropriate that what is a voluntary collaboration helping on regarding a translation, and therefore supposedly free of commitment on both sides, is publicly claimed in the forum. This situation seems to reflect some type of irresponsibility on my part as I am failing to make some type of commitment, which, I insist, there is none. I would sincerely like to receive some kind of explanation as to why you are making a public complaint about a translation job on my part when there is no agreed commitment.
#11 Posted: 6/5/2024 11:25:56 PM
Please forgive me, of course I'm wrong.
Val
Val
1 Pages (12 items)
![2024-06-02 17_15_56-SMath Solver - [3-2-CoolProp-Solve.sm_].png](/en-US/files/Download/ZH6vav/2024-06-02-17_15_56-SMath-Solver---[3-2-CoolProp-Solve.sm_].png)
