1 страниц (12 вхождений)
How to use the solve function in this task - Сообщения
3-2-CoolProp-Solve.sm (46,14 КиБ) скачан 1623 раз(а).
Thanks,
send please the sm-file with the solution
The problem, as you formulated, seems as not having a solution in real numbers, in order to be solved with the solve routine.
I'm sorry but I have no time to reformulate your problem.
If you intend to solve it numerically, try to check the continuity of the function and the fact that in the range you look for solution there is at least one change of the function value sign.
Valery Ochkov 03.06.2024 00:59:00
The problem as stated in the opening post, actually has a solution in the given range.
Yet, I don't see an alternative to using brute force to tame the coolprop function: sampling and interpolation.
Valery Ochkov 03.06.2024 01:50:00
Hi. The guess values, in this case the range, are part of the solution, this means that you must know where the numerical procedure works fine. In this case the interval 1 MPa ... 6 MPa.
3-2-CoolProp-Solve.sm (49,75 КиБ) скачан 1611 раз(а).
Thanks, Martin and Alvaro
See please the problem in attach
Fireless-Locomotive.sm (882,15 КиБ) скачан 1638 раз(а).
PS
Alvaro!
And what about the book?
PS
Alvaro!
Hi Valery. This could be an option.
Fireless-Locomotive.sm (915,8 КиБ) скачан 1638 раз(а).
I'm pretty busy right now! Sorry.
Wrote...
PS
Alvaro!
Valery Ochkov 03.06.2024 16:04:00
It works! By p.0=240 atm
Fireless-Locomotive.sm (882,15 КиБ) скачан 1705 раз(а).
But by p.0=140 atm ---???
Alvaro>
Check please 1-2-3 chapters.
My student from Cuba is waiting for it!
Alvaro>
Wrote... Check please 1-2-3 chapters.
Hi Valery. I find it quite inappropriate that what is a voluntary collaboration helping on regarding a translation, and therefore supposedly free of commitment on both sides, is publicly claimed in the forum. This situation seems to reflect some type of irresponsibility on my part as I am failing to make some type of commitment, which, I insist, there is none. I would sincerely like to receive some kind of explanation as to why you are making a public complaint about a translation job on my part when there is no agreed commitment.
Please forgive me, of course I'm wrong.
Val
Val
![2024-06-02 17_15_56-SMath Solver - [3-2-CoolProp-Solve.sm_].png](/ru-RU/files/Download/ZH6vav/2024-06-02-17_15_56-SMath-Solver---[3-2-CoolProp-Solve.sm_].png)
