Vector basic operations problem - Error occured when adressing the vector's element - Messages
I am newbie, and I guess I've made some silly mistake, somehow misusing the basic functions, but I can't figure out what exactly I made wrong, so I really appreciate your assistance.
Attempt to get the cosine of the vector results in a "Result is above max..." error. Could someone please point out what's wrong?
of_parking_tension.sm (5.13 KiB) downloaded 1240 time(s).
Tnx a lot.
WroteIn Smath, two of the builtin functions needs be
integrate/vectorized ... if not: "x not defined".
Thank you Jean for supplementary explanation, but I'm not sure I got it clearly. Do you mean that if the expression includes more than one built-in function, as in your snippet (cos,sqrt), than it should be vectorized either as in previous example in this thread, or using the loop, as in your snippet? Could you please share some sources from which I could obtain in-depth description of this concept in order to save your time?
Welcome to Smath Community.
Thank you very much. Your attitude is appreciated.
WroteThank you Jean for supplementary explanation, but I'm not sure I got it clearly. Do you mean that if the expression includes more than one built-in function, as in your snippet (cos,sqrt), than it should be vectorized either as in previous example in this thread, or using the loop, as in your snippet? Could you please share some sources from which I could obtain in-depth description of this concept in order to save your time?
The for loop will take any length and export ... simply !
The previous vectorize is a display only. Same not same for end use.
More vector maths attached ... not updated for 6 years.
Cheers, enjoy Smath ... Jean.
VectorField StreamLines Joukowsky Airfoil.sm (38.43 KiB) downloaded 1246 time(s).
Vector Maths Direction Cosine [Dist-in-Space] Copy.sm (83.56 KiB) downloaded 1097 time(s).
Vector Maths.sm (1.07 MiB) downloaded 1274 time(s).
Vector Maths Direction Cosine [Dist-in-Space] Copy.sm (85.52 KiB) downloaded 1095 time(s).
Near all new users doesn't understand him.
Experienced users learned to ignore him.
Search his name in mathcad forums around 2010-2012.
People over there appreciated when he left there.
Because of his unfounded claims and ridiculous posts.
So he left there just continues to pollute this forum.
I look forward to that happy upcoming day of departure of him.
WroteWroteThank you Jean for supplementary explanation, but I'm not sure I got it clearly.
Can you refresh the original demand.
I lost track of it in the blue.
Cheers ... Jean.
WroteCan you refresh the original demand.
There is no need for your useless posts in this topic.
WroteCould someone please point out what's wrong?
First post has the question.
WroteUse array vectorization.
Ber7 already answered it correctly.
WroteGot it, solved. Thanks.
Topic owner thanked as it was the answer.
2 more undefined 'x' complains.
1. Smath Simpson does not recognize the Power Function X^Y
2. Does not recognize Lamvert W(x)
Cheers ... Jean.
WroteThank you very much. Your attitude is appreciated.
You give gf
The for loop returns gf
In most applications you vectorize over sqrt
Some applications needs vectorize inside sqrt and over sqrt
Cheers ... Jean.
Question is already answered.
Don't spam the forum.
https://en.scratch-wiki.info/wiki/Necropost
