3D Plot function help request
3D Plot function help request - Graph input - Messages
#1 Posted: 11/29/2023 7:02:54 AM
Alessandro
Alessandro
1 likes in 18 posts.
Hi
I've got a problem with a 3D plot function.
The function is very simple but i'm not able to find the correct syntax for plot it.
Someone can kindly help me with some advising?
Thancks in advance, i attacched below the Smath reference file where i had higlighted with an arrow the function.
#2 Posted: 11/29/2023 8:26:12 AM
1,362 likes in 2,276 posts.
For instructions on Maxima plots see https://doi.org/10.25933/opus4-2949
Note that the dummy variables need to be undefined in the sheet.
Azioni_Sismiche_Silo_D1101_Kr.sm (1.2 MiB) downloaded 1636 time(s).
#3 Posted: 11/29/2023 7:16:09 PM
Alessandro
Alessandro
Thancks so much for your answer!!!!
I'm very gratefull!
#4 Posted: 11/30/2023 1:19:16 AM
Very easy to get the two circles ... one being shifted.
Tip about X_Y plot ... as soon as you open, give a title.
Next manipulation, click on title.
That technique will save from freaking X,Y ranges.
Jean.
#5 Posted: 11/30/2023 9:48:52 PM
The document from Martin does not work for me.
At this point of the project, if you can attach the matrix,
I may try to render the gray image in RGB.
I have the RGB mapping codes associated with the vectorise code.
Not so sure ... your matrix is huge 360 cols !
