3D Plot function help request
3D Plot function help request - Graph input - Сообщения
#1 Опубликовано: 29.11.2023 07:02:54
Alessandro
Alessandro
1 сообщений из 18 понравились пользователям.
Hi
I've got a problem with a 3D plot function.
The function is very simple but i'm not able to find the correct syntax for plot it.
Someone can kindly help me with some advising?
Thancks in advance, i attacched below the Smath reference file where i had higlighted with an arrow the function.
#2 Опубликовано: 29.11.2023 08:26:12
For instructions on Maxima plots see https://doi.org/10.25933/opus4-2949
Note that the dummy variables need to be undefined in the sheet.
Azioni_Sismiche_Silo_D1101_Kr.sm (1,2 МиБ) скачан 1624 раз(а).
#3 Опубликовано: 29.11.2023 19:16:09
Alessandro
Alessandro
Thancks so much for your answer!!!!
I'm very gratefull!
#4 Опубликовано: 30.11.2023 01:19:16
Very easy to get the two circles ... one being shifted.
Tip about X_Y plot ... as soon as you open, give a title.
Next manipulation, click on title.
That technique will save from freaking X,Y ranges.
Jean.
#5 Опубликовано: 30.11.2023 21:48:52
The document from Martin does not work for me.
At this point of the project, if you can attach the matrix,
I may try to render the gray image in RGB.
I have the RGB mapping codes associated with the vectorise code.
Not so sure ... your matrix is huge 360 cols !
