bug with function with programming
bug with function with programming - calling function with a for loop loops forever - Messages
#1 Posted: 10/14/2019 10:03:17 PM
jcuadra
jcuadra
0 likes in 12 posts.
Firstly thank you for such a wonderful free alternative to MathCad 15.
Please see attached .sm file.
The comments describe the bug ...
Thanks in advance
test bug.sm (16.34 KiB) downloaded 1512 time(s).
#2 Posted: 10/15/2019 4:54:29 AM
Thanks in advance
Did not reproduce it...
Arie 10/15/2019 10:16:00 AM, NDTM Amarasekera 10/15/2019 11:01:00 AM
#3 Posted: 10/15/2019 10:16:05 AM
Arie
Arie
94 likes in 285 posts.
I could not reproduce either..
#4 Posted: 10/15/2019 10:59:18 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Yes, did not reproduce.
#5 Posted: 10/15/2019 1:02:21 PM
jcuadra
jcuadra
Hmm,
I just re-tested on my home PC, freshly booted, same problem.
appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference?
#6 Posted: 10/15/2019 1:17:34 PM
Arie
Arie
Hmm,
I can confirm this hangs on 7030. I was running 7219 before and did not have an issue. My guess is this should be fixed in next stable release and already seems to be fixed in Beta releases. The question is whether or not the "fix" is intentional or not.
#7 Posted: 10/15/2019 1:22:49 PM
jcuadra
jcuadra
OK thanks.
I will install 7219.
Hopefully my Maxima plugin continues to work.
#8 Posted: 10/15/2019 5:43:18 PM
IMHO, not the best option yet.
Who can guess what the angle for loop should be doing ?
There are no maths associated with !
#9 Posted: 10/15/2019 6:05:01 PM
test bug Red.sm (20.37 KiB) downloaded 1435 time(s).
#10 Posted: 10/15/2019 8:26:19 PM
jcuadra
jcuadra
angle was originally used as such, but I modified it as a troubleshooting step, with no change to the bug's behavior
loss := loss + I2ttot(sin(angle*deg)*Ipk)
#11 Posted: 10/15/2019 8:42:45 PM
jcuadra
jcuadra
OK thanks.
It works properly on .7219.
But Maxima doesn't work.
#12 Posted: 10/16/2019 2:09:24 PM
Arie
Arie
What error do you get? Maxima works fine on my end. May need to update the plugin.
#13 Posted: 10/16/2019 4:26:24 PM
jcuadra
jcuadra
^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
EDIT: I was able to get Maxima running with .7219.
#14 Posted: 10/16/2019 6:34:02 PM
No matter SS version, by far not a Mathcad clone.
Show some Mathcad snippets ... would help doctor the patient.
What from Maxima ? Plot, Solve ...
#15 Posted: 10/17/2019 9:30:53 AM
Arie
Arie
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride.
#16 Posted: 10/17/2019 10:14:05 AM
jcuadra
jcuadra
I was able to install Maxima with .7219, thank you.
