Differentiation operator does not evaluate symbolically
Differentiation operator does not evaluate symbolically - Translate a differential operator from SMath to Maxima - Messages
#1 Posted: 5/30/2020 9:46:04 PM
Alvaro Gavilán-Rojas
26 likes in 68 posts.
Do you know why or what could be the problem for SMath not translating properly a dy/dx. I need to write these operators in Maxima to solve a differential equation...
Thanks in advance,
Differentiation.sm (9.34 KiB) downloaded 1159 time(s).
#2 Posted: 5/30/2020 10:23:02 PM
I have found a workaround, with eval_string() from Maxima.
Differentiation.sm (13.39 KiB) downloaded 1168 time(s).
#3 Posted: 5/30/2020 11:55:54 PM
1,139 likes in 1,805 posts.
Hola tocayo. Is this the problem?: always it is diff(y,x)=0, but diff(y(x),x) remains unevaluated and is the correct form to express the derivative of a function.
frapuano 5/31/2020 4:51:00 AM
#4 Posted: 5/31/2020 12:16:30 AM
Hola tocayo, muchas gracias!
Problem solved:
#5 Posted: 5/31/2020 8:12:03 AM
You are mixing two CAS that will not pass QA [Quality Assurance].
My understanding is that what was usable from Maxima is native in Smath.
Smath native derivative operator works from book library.
sin(x), ln(x), exp(x) ... OK
Gamma(x), erf(x) ... zap. We have them otherwise.
Differentiation.sm (17.82 KiB) downloaded 1173 time(s).
#6 Posted: 5/31/2020 10:29:55 AM
Thank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
#7 Posted: 5/31/2020 12:42:32 PM
Very few DE have symbolic solutions, unless from Handbooks.
Few of them are available in Smath ... will be back on that.
#8 Posted: 5/31/2020 6:46:56 PM
If Mathcad Prime does not solve those attached ... Oh !
Cheers ... Jean.
ODE Symbolic 4_Flies.sm (130.62 KiB) downloaded 1195 time(s).
ODE Symbolic Bernoulli.sm (11.38 KiB) downloaded 1213 time(s).
ODE_Laplace 1rst [Type 2].sm (22.68 KiB) downloaded 968 time(s).
ODE Symbolic Verhulst [Logistic].sm (25.55 KiB) downloaded 1034 time(s).
ODE Symbolic Lambert.sm (21.81 KiB) downloaded 1208 time(s).
ODE_Laplace 1rst [Type 1].sm (24.7 KiB) downloaded 987 time(s).
ODE_Laplace 2nd [Type 3].sm (34.62 KiB) downloaded 1046 time(s).
ODE Symbolic Eiffel.sm (21.45 KiB) downloaded 1167 time(s).
