1 Pages (12 items)
Show the Orignal Units in Table Region - Show the original units in the Table instead of the basic units of the International System - Messages
#1 Posted: 3/21/2018 4:01:53 PM
#3 Posted: 3/21/2018 8:22:36 PM
Thanks Sergio:
You made me remember the solution that Martin Kraska gave me, but I can not put a header on it.
Do you have any suggestion?
Units_Table_r2.sm (15.19 KiB) downloaded 1412 time(s).
#5 Posted: 3/22/2018 1:36:09 PM
WroteWill it be possible?
I prefer the way we did in 1987, collecting piles of fluids information.
Units_Table Preference.sm (12.43 KiB) downloaded 1406 time(s).
#6 Posted: 3/22/2018 1:44:41 PM
WroteI thought about this (string manipulation)
but num2strtransforms into fractions
Use var2str() from CustomFunctions instead
#7 Posted: 3/22/2018 8:21:28 PM
Thank you very much to everyone for your help,
I already managed to make the table as I required it.
Units_Table_r3.sm (9.19 KiB) downloaded 1420 time(s).
#8 Posted: 3/22/2018 11:20:16 PM
Thanks Carlos: gorgeous
#9 Posted: 6/26/2018 6:32:55 PM
CBG,
Using the unit summary to convert units back to original units doesn't work for temperature conversions. What you are doing with the units summary assumes the conversion is a factored multiplier. It works great for everything except temperature (or any other unit doesn't scale by a factored multiplier).
#10 Posted: 6/26/2018 9:28:04 PM
#11 Posted: 6/26/2018 9:49:54 PM
#12 Posted: 6/26/2018 11:59:58 PM
WroteMaybe try something other than 20 deg?...
You are quite right and there are two things here
1. As it looks, the °C can't be made user.
The unit system is grounded on 'K', bloody pest to me.
2. The other thing is the Shadow in context, a real bug.
It worked fine from Carlos original [by what coincidence ?]
Not changing the context, context reproduces. Changing context
and the all thing °C gets freaked. I observed that many times
in Smath. In fact, very problematic.
Thanks for this wise observation.
Table Region Carlos.sm (10.6 KiB) downloaded 1359 time(s).
1 Pages (12 items)
