1 Pages (12 items)
How i can write this formula in Smath Studio? - How i can write this formula in Smath Studio? - Messages
#1 Posted: 5/18/2018 10:05:41 AM
I have one formula where it is necessary to make a sum in a way that takes into account 5 coefficients of a polynomial. In the sum he is marked as ak and I need that instead of ak there was a1..a2..a3 ... a4 ... a5. Also, for each polynomial account, the power K automatically changes from the index of the polynomial 1..2..3..4..5. How to implement it in this program? Also, I have several layers of reinforcement in the equation that should also be instead of Asi to As1...As2...As3...Asn and Sigma_si to Sigma_s1...Sigma_s2...Sigma_s3...Sigma_sn . Sorry for bad English.
Arkush1.sm (11.61 KiB) downloaded 1181 time(s).
#2 Posted: 5/18/2018 10:32:44 AM
You made the following error: you used "a.k" instead of "a[k". This way you did not create vectors to use in the summation with the counter. You need to do to define and then use As and Sigmas.
yuriy1996 5/18/2018 11:16:00 AM
#3 Posted: 5/18/2018 10:38:06 AM
I corrected a.k for a[k but how do I set 5 values for one variable a[k?
#4 Posted: 5/18/2018 10:55:32 AM
for example a[1:=2.5 a[2:=3.21 a[3:=-7.1
so "a" is a vector
in the sum a[k
so "a" is a vector
in the sum a[k
yuriy1996 5/18/2018 11:15:00 AM
#5 Posted: 5/18/2018 11:13:48 AM
Unable to determine the value of an element since the item with the specified index does not exist -error
#6 Posted: 5/18/2018 11:16:25 AM
Arkush1.sm (14.27 KiB) downloaded 1206 time(s).
#8 Posted: 5/18/2018 12:29:55 PM
#9 Posted: 5/18/2018 1:18:18 PM
Wrote... you may clean/recast a bit.
You have 11 sets of 'a'
Easy to tabulate, is it what you want ?
#10 Posted: 5/18/2018 1:51:50 PM
Pl look at this. Error may have occurred when entering the formula???? Difficult to trace.
Unable to select individual components of the erroneous formula.
Arkush1_ndtma.sm (16.76 KiB) downloaded 1188 time(s).
#11 Posted: 5/18/2018 2:53:49 PM
WroteYou have 11 sets of 'a'
Arkush1_CBG [data].sm (136.18 KiB) downloaded 1000 time(s).
#12 Posted: 5/18/2018 9:34:10 PM
WrotePl look at this. Error may have occurred when entering the formula???? Difficult to trace.
There it seems the formula is ill posed wrt [4.1].
It shows bfcd as something not defined but the originator
has defined b, and defined fcd ... b*fcd.
1 Pages (12 items)
