Find and replacement
Find and replacement - Messages
#1 Posted: 1/30/2021 6:24:43 AM
netsonicyxf
netsonicyxf
2 likes in 79 posts.
  1. There is no replace option.
  2. I suggest use muti-level-criteria for find and replace selection:
    The first level is
    whole document / from mouse point above / from mouse point below /select regions
    The second level is
    all / text / math
    The third level applies to math only
    all / variable only / subscripts only / superscripts only
#2 Posted: 1/30/2021 9:50:03 AM
Replace what, where by what ?
In math regions we have:
click the var/parameter, F8, back space, new.
#3 Posted: 1/30/2021 10:57:12 AM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
I can see uses, especially with the NEW document mode. Andrey even improved the search feature in 0.99.7691 BETA.
#4 Posted: 1/30/2021 11:26:56 AM
netsonicyxf
netsonicyxf
I tried it, it has some limits
  1. it works for variable only, but it doesn't work for super/sub-script.
  2. it only work in one region for one time, it not work for multiple regions or the whole document.
  3. it doesn't work for text regions.
#5 Posted: 1/30/2021 3:38:42 PM
  • it works for variable only, but it doesn't work for super/sub-script.
  • it only work in one region for one time, it not work for multiple regions or the whole document.
  • it doesn't work for text regions.
  • 1. It works for parameters as well.
    2. Works for interlated regions, as multiple times.
    3. Zap part of text, paste or compose new stuff.
