Find and replacement
Find and replacement - Сообщения
#1 Опубликовано: 30.01.2021 06:24:43
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
  1. There is no replace option.
  2. I suggest use muti-level-criteria for find and replace selection:
    The first level is
    whole document / from mouse point above / from mouse point below /select regions
    The second level is
    all / text / math
    The third level applies to math only
    all / variable only / subscripts only / superscripts only
#2 Опубликовано: 30.01.2021 09:50:03
Replace what, where by what ?
In math regions we have:
click the var/parameter, F8, back space, new.
#3 Опубликовано: 30.01.2021 10:57:12
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
I can see uses, especially with the NEW document mode. Andrey even improved the search feature in 0.99.7691 BETA.
#4 Опубликовано: 30.01.2021 11:26:56
netsonicyxf
netsonicyxf
I tried it, it has some limits
  1. it works for variable only, but it doesn't work for super/sub-script.
  2. it only work in one region for one time, it not work for multiple regions or the whole document.
  3. it doesn't work for text regions.
#5 Опубликовано: 30.01.2021 15:38:42
  • it works for variable only, but it doesn't work for super/sub-script.
  • it only work in one region for one time, it not work for multiple regions or the whole document.
  • it doesn't work for text regions.
  • 1. It works for parameters as well.
    2. Works for interlated regions, as multiple times.
    3. Zap part of text, paste or compose new stuff.
