Finding Roots of a large system of equations
Finding Roots of a large system of equations - Having trouble with the syntax - Messages
#1 Posted: 9/23/2024 5:34:57 AM
RegRetired
RegRetired
8 likes in 144 posts.
See attached sm file.
I am trying to find the k values of alpha that are roots of the system of k transcendental equations. I don't understand the required syntax.
I have the equivalent MATHCAD 15 file if that is helpful to anyone.
Thanks for all help.
Reg
LITTLE BOY LAMBDA AND ALPHA.sm (86.48 KiB) downloaded 1400 time(s).
Reg CurryLoveland, CO
#2 Posted: 9/23/2024 9:18:02 AM
1,123 likes in 1,795 posts.
Hi Reg. You can try this.
LITTLE BOY LAMBDA AND ALPHA.sm (93.57 KiB) downloaded 1459 time(s).
#3 Posted: 9/23/2024 9:58:57 AM
RegRetired
RegRetired
Alvaro,
Thanks. I will give that a try. I found a couple of typos in my definition of the elements of F. But, I will fix that and try your method.
I got a little further using the solve function; however, I am having trouble getting it to plot.
LITTLE BOY LAMBDA AND ALPHA.sm (63.61 KiB) downloaded 1425 time(s).
Thanks again,
Reg
