FIR Filter Design
FIR Filter Design - Calculation of digital filter coefficients - Messages
#1 Posted: 5/6/2013 3:05:06 PM
1,558 likes in 1,868 posts.
FIR Filter Design
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Functions list: remez(4), remez2(4).
remez(vg, vr, vw, n) Returns coefficients for a FIR filter of length n generated by the Remez exchange algorithm.
Arguments:
- vg is a real vector, a grid of frequencies between 0 and 0.5.
- vr is a real vector of values between 0 and 1, length: vg / 2. Contains the frequency response over vg.
- vw is a real vector of values between 0 and 1, the same length as vr. Contains error weight over vg.
- n is an integer, the length of the filter.
Links:
1. Based on Parks-McClellan algorithm for FIR filter design (C version) by Jake Janovetz (part of the Analysis of Functional NeuroImages - a set of C programs for processing, analyzing, and displaying functional MRI (FMRI) data).
2. Parks-McClellan filter design algorithm.
remez.sm (13.43 KiB) downloaded 1868 time(s).
remez.pdf (48.9 KiB) downloaded 1188 time(s).
See also:
1. Design FIR band-pass/stop filters up to length ~2000
FIRFilterDesign. Example 1 (rus).pdf (100.06 KiB) downloaded 1098 time(s).
Davide Carpi 5/6/2013 5:21:00 PM, Andrey Ivashov 5/6/2013 5:41:00 PM
#2 Posted: 11/17/2021 5:20:00 PM
Plugin updated. Please try.
Changes:
- remez2() function added.
Links:
1. Sources from tomtit
2. Test example for remez2().
#3 Posted: 12/29/2021 2:34:56 PM
Calculation of digital filter coefficients for emulation/design High-Class Audio Multi-function Digital Filter SM5842AP/APT.
High-Class Audio Multi-function Digital Filter (SM5842AP-APT).sm (26.64 KiB) downloaded 1678 time(s).
High-Class Audio Multi-function Digital Filter (SM5842AP-APT).pdf (169.04 KiB) downloaded 966 time(s).
SM5842AP.pdf (218.37 KiB) downloaded 1182 time(s).
Click to enlarge Click to enlarge
Links:
1. The example is audiophile's "holy" NPC SM5842 8X interpolating digital filter.
Davide Carpi 12/29/2021 8:17:00 PM
