Double Integration using ode solvers
Double Integration using ode solvers - Messages
#1 Posted: 6/4/2020 1:40:08 AM
1,139 likes in 1,805 posts.
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42.67 KiB) downloaded 1456 time(s).
DoubleIntegralRK.pdf (219.12 KiB) downloaded 1022 time(s).
frapuano 6/4/2020 4:03:00 AM, sergio 6/4/2020 4:42:00 AM
#2 Posted: 6/7/2020 1:21:46 PM
SteelCat
SteelCat
3 likes in 47 posts.
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
#3 Posted: 6/7/2020 7:50:25 PM
Can the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6.33 KiB) downloaded 1173 time(s).
#4 Posted: 6/17/2020 8:21:22 PM
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60.58 KiB) downloaded 1453 time(s).
GaussLegendreQuadrature.pdf (160.77 KiB) downloaded 1032 time(s).
Yes.
DoubleIntegralSteelCat.sm (47.08 KiB) downloaded 1426 time(s).
DoubleIntegralSteelCat.pdf (105.49 KiB) downloaded 845 time(s).
sergio 6/18/2020 5:14:00 AM, frapuano 6/18/2020 7:33:00 AM
#5 Posted: 6/18/2020 11:26:19 AM
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28.98 KiB) downloaded 1206 time(s).
#6 Posted: 6/18/2020 9:35:42 PM
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25.63 KiB) downloaded 1388 time(s).
DoubleIntegralJean.pdf (45.11 KiB) downloaded 945 time(s).
sergio 6/19/2020 5:41:00 AM, frapuano 6/19/2020 9:34:00 AM
#7 Posted: 6/20/2020 7:39:28 AM
Thanks, Amigo !
