Double Integration using ode solvers
Double Integration using ode solvers - Сообщения
#1 Опубликовано: 04.06.2020 01:40:08
1 125 сообщений из 1 799 понравились пользователям.
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42,67 КиБ) скачан 1372 раз(а).
DoubleIntegralRK.pdf (219,12 КиБ) скачан 934 раз(а).
frapuano 04.06.2020 04:03:00, sergio 04.06.2020 04:42:00
#2 Опубликовано: 07.06.2020 13:21:46
SteelCat
SteelCat
3 сообщений из 47 понравились пользователям.
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
#3 Опубликовано: 07.06.2020 19:50:25
Can the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6,33 КиБ) скачан 1087 раз(а).
#4 Опубликовано: 17.06.2020 20:21:22
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60,58 КиБ) скачан 1369 раз(а).
GaussLegendreQuadrature.pdf (160,77 КиБ) скачан 936 раз(а).
Yes.
DoubleIntegralSteelCat.sm (47,08 КиБ) скачан 1337 раз(а).
DoubleIntegralSteelCat.pdf (105,49 КиБ) скачан 765 раз(а).
sergio 18.06.2020 05:14:00, frapuano 18.06.2020 07:33:00
#5 Опубликовано: 18.06.2020 11:26:19
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28,98 КиБ) скачан 1124 раз(а).
#6 Опубликовано: 18.06.2020 21:35:42
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25,63 КиБ) скачан 1302 раз(а).
DoubleIntegralJean.pdf (45,11 КиБ) скачан 861 раз(а).
sergio 19.06.2020 05:41:00, frapuano 19.06.2020 09:34:00
#7 Опубликовано: 20.06.2020 07:39:28
Thanks, Amigo !
