Conversion between Cartesian coordinates and Geodetic coordinates
Conversion between Cartesian coordinates and Geodetic coordinates - Messages
#1 Posted: 8/31/2021 4:54:17 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
often found in geodesy and astronomy, for example, when
determination of location by GPS.
Converting geodetic coordinates to Cartesian coordinates is not difficult.
Converting Cartesian coordinates to geodetic coordinates is more difficult
because. the transformation formulas include the projection of a point onto
the surface of the Earth's ellipsoid.
In this program, the calculation of the orthogonal projection is borrowed
from the program
https://en.smath.com/forum/yaf_postsm69369_Draghilev-method-revisited.aspx#post69369
statya revolution.sm (74.77 KiB) downloaded 1208 time(s).
revolution.pdf (349.09 KiB) downloaded 861 time(s).
#2 Posted: 8/31/2021 8:28:23 AM
Fridel Selitsky
Fridel Selitsky
Converters of direct and inverse transformation of coordinates
Geod to Cart.sm (44.9 KiB) downloaded 1228 time(s).
Cortesian_to_Geodetic.sm (50.69 KiB) downloaded 1254 time(s).
Alvaro 8/31/2021 9:47:00 AM
