Conversion between Cartesian coordinates and Geodetic coordinates
Conversion between Cartesian coordinates and Geodetic coordinates - Сообщения
#1 Опубликовано: 31.08.2021 04:54:17
Fridel Selitsky
Fridel Selitsky
often found in geodesy and astronomy, for example, when
determination of location by GPS.
Converting geodetic coordinates to Cartesian coordinates is not difficult.
Converting Cartesian coordinates to geodetic coordinates is more difficult
because. the transformation formulas include the projection of a point onto
the surface of the Earth's ellipsoid.
In this program, the calculation of the orthogonal projection is borrowed
from the program
https://en.smath.com/forum/yaf_postsm69369_Draghilev-method-revisited.aspx#post69369
statya revolution.sm (74,77 КиБ) скачан 1208 раз(а).
revolution.pdf (349,09 КиБ) скачан 861 раз(а).
#2 Опубликовано: 31.08.2021 08:28:23
Fridel Selitsky
Fridel Selitsky
Converters of direct and inverse transformation of coordinates
Geod to Cart.sm (44,9 КиБ) скачан 1228 раз(а).
Cortesian_to_Geodetic.sm (50,69 КиБ) скачан 1254 раз(а).
Alvaro 31.08.2021 09:47:00
