Findstr function
Findstr function - Messages
#1 Posted: 2/17/2014 8:22:59 AM
127 likes in 342 posts.
It seems that the "findstr" function gives a numeric value of type special format.
For this reason the Boolean operations on the result would not work properly .
[albumimg]345[/albumimg]
#2 Posted: 2/17/2014 8:30:39 AM
1,442 likes in 2,934 posts.
Hi Sergio,
Is not a bug of findstr, this returns a list of matches or -1 (but boolean's lacks are already known)
You need to change the logic of your script (see the attachment)
Best regards,
Davide
#3 Posted: 2/17/2014 11:11:40 AM
Thanks for the explanation Davide,
as you have pointed out, the Boolean implementation needs to be improved.
Your trick has worked well.
