Findstr function
Findstr function - Сообщения
#1 Опубликовано: 17.02.2014 08:22:59
123 сообщений из 341 понравились пользователям.
It seems that the "findstr" function gives a numeric value of type special format.
For this reason the Boolean operations on the result would not work properly .
[albumimg]345[/albumimg]
#2 Опубликовано: 17.02.2014 08:30:39
1 441 сообщений из 2 930 понравились пользователям.
Hi Sergio,
Is not a bug of findstr, this returns a list of matches or -1 (but boolean's lacks are already known)
You need to change the logic of your script (see the attachment)
Best regards,
Davide
#3 Опубликовано: 17.02.2014 11:11:40
Thanks for the explanation Davide,
as you have pointed out, the Boolean implementation needs to be improved.
Your trick has worked well.
