How to apply initial conditions in second-order differential equations
How to apply initial conditions in second-order differential equations - How to apply initial conditions in second-order differential equations - Messages
#1 Posted: 12/7/2025 3:59:55 AM
kimkim
kimkim
0 likes in 9 posts.
The solution to the second-order differential equation has been obtained as follows.
If we want to find the solution by applying the initial conditions y(t)=0, y'(t)=0,
what should I do in the following steps?
thank you for your help.
Edited 12/7/2025 6:53:24 AM
#2 Posted: 12/7/2025 9:07:00 AM
StvMath
StvMath
44 likes and 1 dislikes in 71 posts.
Once you've got y(t) you could simply do the following:
kimkim 12/7/2025 9:41:13 PM
#3 Posted: 12/7/2025 12:54:45 PM
1,356 likes in 2,271 posts.
If you don't need the function v(t), you can specify the initial conditions directly: (example 10.2 in https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath)
3 users liked this post
sergio 12/7/2025 5:07:45 PM, kimkim 12/7/2025 9:41:18 PM, ioan92 12/9/2025 10:52:27 AM
