How to apply initial conditions in second-order differential equations
How to apply initial conditions in second-order differential equations - How to apply initial conditions in second-order differential equations - Сообщения
#1 Опубликовано: 07.12.2025 03:59:55
kimkim
kimkim
0 сообщений из 9 понравились пользователям.
The solution to the second-order differential equation has been obtained as follows.
If we want to find the solution by applying the initial conditions y(t)=0, y'(t)=0,
what should I do in the following steps?
thank you for your help.
Отредактировано 07.12.2025 06:53:24
#2 Опубликовано: 07.12.2025 09:07:00
StvMath
StvMath
44 сообщений из 71 понравились и 1 не понравились пользователям.
Once you've got y(t) you could simply do the following:
kimkim 07.12.2025 21:41:13
#3 Опубликовано: 07.12.2025 12:54:45
1 356 сообщений из 2 271 понравились пользователям.
If you don't need the function v(t), you can specify the initial conditions directly: (example 10.2 in https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath)
sergio 07.12.2025 17:07:45, kimkim 07.12.2025 21:41:18, ioan92 09.12.2025 10:52:27
