Signals and Systems - Example of use of SMath for signals and systems analysis - Messages
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Thanks Davide!!
The post shows a trasfer function solved for the poles and zeros... It looks like you have to know how many poles and zeros to solve for before getting going. That would require putting the transfer function in standard form I'm somewhat sure.
https://electronics.stackexchange.com/questions/243435/bode-plot-of-transfer-function?rq=1
WroteI'm still trying to get the hand of this software. I'm an e.e. undergraduate and would like to be able to perform the something like the mathcad at the end of this post. I did try to input a similar syntax but I'm too much of a noob to work it. Can anyone shed some light on this for me?
All documents attached are in Smath 6179, should work same imore recent version(s).
The Smath/Maple companions of this year [2018] work a bit different than Mathcad 11 [2003].
At the end, all attached documents work for me Smath 6179 same as my former Mathcad 11.
Inst_PID [ODE].sm (24.75 KiB) downloaded 1107 time(s).
Inst_PID Discrete State Systems.sm (25.51 KiB) downloaded 1342 time(s).
Inst_PID DynSys.sm (14.9 KiB) downloaded 1257 time(s).
Inst_PID [PI, PID].sm (71.51 KiB) downloaded 1123 time(s).
Inst_PID [P, PD].sm (106.94 KiB) downloaded 1051 time(s).
Inst_PID Feedback Attenuator.sm (43.76 KiB) downloaded 1283 time(s).
Inst_PID [MCD Model].sm (177.96 KiB) downloaded 1120 time(s).
Inst_TurboGen Smath.sm (106.19 KiB) downloaded 1310 time(s).
ODE_Laplace Read First.sm (27.41 KiB) downloaded 1316 time(s).
Inst_TurboGen Signum.sm (91.08 KiB) downloaded 1353 time(s).
Inst_PID Discrete Schema.sm (166.36 KiB) downloaded 1347 time(s).
ODE_Laplace 1rst [Type 1].sm (24.7 KiB) downloaded 1120 time(s).
Inst_XFR 2nd [XFR nth].sm (34.08 KiB) downloaded 1125 time(s).
ODE_Laplace 1rst [Type 2].sm (22.5 KiB) downloaded 1196 time(s).
Inst_PID DynSys_v01 (1).sm (235.59 KiB) downloaded 1306 time(s).
ODE_Laplace 2nd [Type 3].sm (33.42 KiB) downloaded 1133 time(s).
ODE Laplace Kinetic Reaction.sm (93.13 KiB) downloaded 1307 time(s).
Here's an example of how one might attack it.
Page1.sm (44.98 KiB) downloaded 1531 time(s).
Bravo! Alyles, simple and beautiful!!
What why the invlaplace I get a dot?
Inverse Laplace-1.sm (4.08 KiB) downloaded 1355 time(s).
Basile
WroteJean,
Basile, mon ami, you need a new pair of glasses !
Just code as the snippet, it will gladly work for Basile.
Until I get my new pair, I see that a dot appears after the F(s) when I type a comma.
Any diagnosis?
Inverse Laplace-2.sm (4.25 KiB) downloaded 1287 time(s).
Basile
WroteJean,
Any diagnosis?
Check from "Options" if you can fix .
Can you be more specific?
Basile
WroteJean,
Basile
From the menu tool bar up top work sheet:
Tools => Options => Interface => Arguments separator [period, coma, semicolon]
Thank you,
Basile
People have done some amazing things with it that I can't even begin to follow but I haven't been as successful. Perhaps as I become more competent I might be more successful but for now I think I will unfortunately have to hang up my hat gentlemen... I bid you a respectful adieu for the time being kind Sirs...
magnetism.zip (5.26 MiB) downloaded 497 time(s).
WrotePerhaps as I become more competent I might be more successfu
I have doctored few things in these two documents.
hw 2.6.sm (133.49 KiB) downloaded 1280 time(s).
open loop gain from closed loop gain 2.sm (48.32 KiB) downloaded 1273 time(s).
WroteHi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Oscar Campo
Hi. Enjoyed & Improved. Six years later.
InvLaplace2.sm (93.88 KiB) downloaded 1311 time(s).
WroteEnjoyed
Thanks Alvaro for your dedication,
Does syntax error 6179, but does not to where it complains.
Don't worry, OK like this.
The 2nd example is lot more involved, correct [sanity MCD].
InvLaplace2 Otherwise.sm (27.68 KiB) downloaded 1337 time(s).
